Best gaming case under £200 for Air flow
11 Jul 2010
ENgland, Oxford
Tittle says it peoplez best gaming Pc case under £200
for me i think the antec 1200 or the HAF 932
the cases must support the antec Truepower quattro PSU and the Gigabyte Ud7 for the intel core i7, and a very big graphic cards, reason for all of these is out of interest
and also LOOKS IS A good thing for me is well, some cases that come with windows so you can show off whats inside :)
Coolermaster CM-690 II Advanced gets my vote, excellent case, though im not sure about the biggest cards with it, 5850 fits fine with room to spare :)
I suppose it also depends what you are fitting into it:
For me it's 5 x drives, USB card, 1 x 5870 (maybe 2 come winter) etc...
FTO1, great air flow, works on positive air pressure so you get very little dust inside your case.
I can second this. I went from an antec 900 which was noisy as hell to a Silverstone FT01 and i've never looked back.
The ft01 used to be one of the best cases for cooling a cpu on air, graphics card wasn't class leading but still perfectly adequate. Its absolutely silent too due to the size of the intakes.
