which card are you upgrading to a gtx460
4 Jun 2008
west yorkshire
im thinking of going from a gtx260,but think i might not notice too much difference,which card are you upgrading from.
Im thinking about going from a gtx280, also not sure if it would be worth it though
Reckon I would probably get the gainward golden sample gtx460 if I did
Thinking of going for a 1gb 460 here, because of my faulty 8800gtx - if my card wasnt faulty, I wouldn't really want/need to upgrade.
Also If I went for the 768mb version it wouldnt be much of an upgrade imo. 8800gtx shares the same ram and rops as the 460, I know its not like for like when it matches up to final performance, but still...
Considering upgrading from my Superclocked gtx 260 but keep asking myself whether the performance percentage is worth it for the extra dosh.
Would opt for a pre-overclocked 1gb 460 if i did.
same,but are we just falling for the hype of a new card,my gtx260 runs all i can throw at it,
Honestly guys and girls, if you can handle applications you use currently, don't bother upgrading because when you need to, something better will be available.
@cainer:Upgrade your 5870s for one????
WTF???
Your joking?
tbh im more inclined to get another 5870 for trifire (ive been told this adds at least 1" to ur epeen, just imagen how crazy the birds will go down the pub when i tell em ive 3 gpu's, theyl be all over me :p )
Not the best tactic, there's always someone stood behind you with 4 gpu's :(
Dam them!
Dam them!
we normally take them out the back and give them a good beating, unless there underwater @ 1100+/1300+ then we bow down and offer them our g/f as their never likley to encounter this phenomenal length of epeen again in their lives
:p
