Of course a bit of dipping is normal, unless you have a brand new Rolls-Royce V12 or similar. However, this is definitely abnormal. You'll be sitting there, it will be rock stable, then you'll get a little shudder as it randomly drops to 500 RPM, then just raises back up... and it would seem nothing has happened to cause it to cause it.
I think if most people look at their rev counters on their way home tonight they will see that its quite normal in any brand of car. I could be wrong though, it could be something more sinister but you will see what I mean if you are stationary, at idle and press the brake pedal or something
Unfortunately, you're right - it could be any number of air/vacuum related things. Even more unfortunately, unless it was caused by you loading the engine too much at once (like the pusher fan, AC compressor, lights, radio etc. all suddenly draining a lot), it will probably happen againI'm hoping it doesn't happen again and it's nothing to be concerned about, will have to see how it goes
