The E46 saloon windows rattle after some time as well against the frame/seals but only on dry days.
It's a feature!
Would replacing the seals with tighter fitting ones not stop this?
[TW]Fox;16946681 said:No.
The problem is that the seals rub against the bodywork and creak, not that the seal is not tight enough.
[TW]Fox;16946793 said:How many more times do you want me to explain it
If he's talking about the same issue that plagues the E39, E46 and E60, which I imagine he is, the reason behind it is as I've explained. There are about 20 different ideas of why it happens and no real fix. BMW have constantly redesigned the seals to no avail.
The E60 has no such creaks
Robbies being more exagerated because it's frameless glass.
Indeed.[TW]Fox;16947480 said:Oh yes it does - the pre LCI certainly does.
