any tips for painting inside of your pc case?
7 Jul 2010
Peterborough
hello there, thinking of painting the inside of my case tomorrow as its just bare metal atm and ive seen most pc cases with black inside and i feel that it looks a lot better. any good tips people know before i go ahead and paint it tomorrow?
thanks,
You might want to do a bit of a google into the do's and dont's of painting metal and the method of painting your going to use, such as spray or brush :)
I'm sure there's a few good videos on you tube. I thought about painting an old case I had. Spraying is much better than brushing, sand down & clean the case, at least 2 lightly applied coats with overnight drying in-between, if your case comes apart, like top, bottom, sides etc, take it apart and hang it up.outside on a washing line.
here is a tip put the motherboard standoffs in place when you spray it as they can be a PITA to get back in if the internal threads are full of paint.
I remember a guy posting about trying to spray his computer while it was turned on, as he didn't want to stop his downloads...
Probably an attention seeker but it did make me laugh.
I remember that too, was quite weird.
Depending on your budget, I'd send it to TTL Customs! :) Some brilliant work if you want something original, however if you're planning on doing it yourself, might want to just pop down the local hardware shop and get some paint and primer.
