So what makes it different to two separate cards that allows it to use all 3gb then?
2 480's can use 2x 1.5gb as 3gb?
my cf 1gb 5870's dont = 2gb of usable vram, its still only 1gb of usable vram
my cf 1gb 5870's dont = 2gb of usable vram, its still only 1gb of usable vram![]()
water, or a damn good air cooler
Remember you have to take into accounts memory mapping (on my 9600 1.5gb aaaargh), so using such a stupid (read:not as much as those toxic 5970 trollolololol cards) may actualy tone down the performance of your pc as a whole. Unless you are using Windows 7. In which case ignore this =Pyou've lost me? it all depends on what game/application is using it.
i never head of them using the ram more then normal sli?
remember in chats that it may be using 3GB where as a single one may use 1.5GB in sli but there's still another one using another 1.5GB
1.5 + 1.5 = 3GB
no it is literally taking two gtx480's and putting them on once pcb. the only addition is a pcie bridge.
overall the card has 3GB but its 1.5GB to each gpu. the memory is not able to be shared.
