- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Corsair Obsidian 700D Full Tower Case - Black @ £162.98 inc VAT
The steel structure has a matte black coating both inside out and is finished with a brushed aluminum faceplate for a professional look that’s both serious and awe-inspiring.
The power supply compartment, main compartment and the SATA bays each have dedicated cooling subsystems to prevent heat buildup.
A dust-filtered 140mm fan draws in cold air at the bottom of the chassis and exhausts it at the rear and top. This clever design forces fresh air directly over the graphics card and CPU. The hard drive / SSD bays are cooled by a separate 140mm fan which vents from the chassis via a sealed chamber and prevents the heat generated by the drives from entering the main compartment. The power supply compartment has its own dedicated intake and exhaust, also isolated from the main compartment.
Need even more cooling performance? The Obsidian Series 700D has pre-drilled support for top-mounted single, dual, and triple radiators, or up to three additional 120mm fans.
Advanced Features for Extreme Flexibility.
Six drive bays with clever snap-in trays accommodate both 3.5” and 2.5” drives with no adapter necessary. A unique cable routing system virtually eliminates cable clutter that can impede airflow. The tool-free design allows for easy entry, easy access, and quick installation of 5.25” drives.
- Six HDD / SSD drive bays compatible with both 3.5” and 2.5” drives
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Two year warranty with Corsair’s world-class customer service and technical support
- Dimensions: (609mm X 609mm X 229 mm)
- 5 x 5.25" Drive Bays
- 6 x 3.5" or 2.5" Drive Bays
- Front I/O: 4 x USB2.0, 1 x FireWire, 2 x Audio
Only £162.98 inc VAT.
ORDER NOW
ORDER NOW
