Wacom graphics tablets...
22 Jan 2010
... what exactly do you get for the money? I have a Wacom bamboo and it's great apart from it's so tiny. Every inaccuracy in my stroke is multiplied 4 fold on the screen unless I zoom in a lot but I don't like working like that.
There are plenty of much bigger tablets from other manufacturers for well under £100, where as getting a Wacom of the same size is often over £200. Is it really worth it?
From what I've experienced. this is what we can say
Does size matter?
The bigger the tablet, the harder it is to stroke. The stokes performed by the hand physically is now longer, and even with the right texture nib, the wanted stroke line is harder to come out 'right', With an A4< pad, I usually repeat the stroke atleast 5/6 times to get it right, for this reason i have ctrl+z on as a short cut on the wacom utility button. I think I therefore prefer using smaller tablets and zooming as necessary. Those buttons on the bamboo make this sooooo much easier, the scroll wheel can be set to zoom AND rotate the canvas while another button is set to pan (as default setting on most software), and as the shortcuts are already in your utility buttons, once you get used to it, it will be as natural as moving and rotating a sketch book by hand.
2 of my house mates had el cheapo tablets, forgot the brands but one of them was horrendous, the refresh rate or something was not right, quicker strokes comes out as angular set of lines, the drives often drive the CPU to insanity, and to top this off, it was falling apart and had no buttons or scroll wheels on the tablet it self.
I've not tried the Bamboo seriously (only in shops), but I would suggest giving it some time, and getting used to drawing on the wacom fully using those keys and scroll wheels and see how you feel. Obviously if you get the chance, do try different brands, but i'm sure you will just appreciate having wacom sensors more.
and remember, drawing on the computer is not the same as drawing in real life, comparing the two is a rather hard task by it self due to the uncountable amounts of positives and negatives of both.
I hope this helps.
Finally, the house mates i lived with were all Students, so none of the opinions were professional. But we all agree with our findings.
Thanks for the input, so if I do decide I want to get a bigger tablet I am probably better off just saving for a wacom? I know a friend who has a cheapo a4 tablet, I should ask to give it ago.
(I am also a student)
What about buying older models, for example getting a second had intous 2 or 3 instead of a 4. Is this a good idea or is there really a dramatic difference?
I have an Aiptek 600u Premium II (A4 tablet) which is alright for drawing considering it was only £60, a decent sized wacom tablet will empty your wallet though i would bare that in mind
I think at this point you're better off just trying to get used to the A6/A5 ones, having the huge pad to screen ratio is annoying compared to the 1:1 ratio of traditional media, but having a larger tablet can have difficulties of it's own.
Older Wacom tablets are probably just as good in terms of the sensory components for students like us to use :) I mean, from the short use i had on the Bamboo, i couldn't feel much of a difference. (needs looking in to though)
Iv got the intuos 3. But i really do look up to the scroll wheel LCD indicated buttons, and the onscreen option selector thing. Being able to rotate the canvas like that is absolutely awesome.
An awesome tip i can give you is to have another screen showing the navigator tool on full screen with Photoshop. that way you can zoom in with the working screen to draw while being able to see what you just did on a broader view.
Also, make sure the sensor aspect ratio on the wacom is the same as the screens in the setting option. I was baffled at first when circles i drew came out oval on the screen :P.
Ok, good to know.
By the way am I weird for wrapping paper round mine? I dunno, it just makes it feel like, well, drawing on paper, plus I used it as a mouse mat for a bit and kind of wore away the texture of the surface ^.^
