Hello OcUk Forums,
I am looking for some help in analysing the performance difference between these two different AMD®/Intel® platforms and trying to understand the Pro's and Con's of each a bit better!
I've got some builds coming up soon that pretty much need to do everything and last two or three years before needing an overhaul and have come up with the following specs . . .
Beastly-Box Summer 2010 Requirements:
The specs above have been carefully considered and selected for their technology, quality and price . . . there are slightly more affordable options for the memory and motherboard on both Intel® and AMD® systems but TBH the saving from downgrading either platform are very small and do not address the reasonably large price premium . . . using the specs above I am faced with having to justify an additional £139.78 - £157.41 for the Intel® Core™ i7 systems and have so far not been able to uncover some really "compelling" performance benefits for the Intel® premium . . .
I did ask some questions in another thread hoping someone could give me an insight into the performance differences between these two platforms but have thus so far come up with no meaningful answer . . . in the benchmarks I have seen so far the Intel® Core™ i7 seems to perform a bit better in gaming but I'm not sure if the games would be noticeably slower using the AMD® Phenom™ II X6? . . .
On the Multimedia-production side of things it's six of one and half a dozen of the other, certainly not enough performance coming from the Core™ i7 that I've seen yet to convince me (and the clients) that the premium is worth paying? . . . if the price difference was a bit closer I think the selection process would be easier but as it stands tech-for-tech I need help coming up with some solid "justification" . . . well beyond the old "Intel® Inside" branding blag!
In case anyone suggests that a cheaper build is possible by "downgrading" the components listed above I've already looked into that, by choosing slower ram and less well technology featured motherboards the price difference becomes £124.05 - £147.55 which I personally feel makes it a moot point i.e downgrading the specs saves £10-£15 from *both* builds and in the best case scenario leaves me still to "justify" at minimum a £124.05 price difference and removes the ability of both systems to overclock (worse cooler) and less technology (no SATA 6Gb/s/USB 3.0 option) . . . I think for the really slight saving it makes sense to go with one of the specs posted above and get maximum technology for £10-£15 extra on either platform . . . seem reasonable enough?
I've found the following benchmark data at Anandtech which compares a much more expensive Intel® and AMD® processor but they are both running at the same speed . . . I'm not considering buying either of these two chips but for clock-for-clock comparison it kinda gives a feel for how both an Intel® Core™ i7 920/930 compares to a AMD® Phenom™ II X6 1055T . . . the thinking here is that 3.2GHz vs 3.2GHz is going to have the same "relative" performance as a 2.8GHz/2.8GHz . . . I did make a thread to question the validity of that assumption here but not had any confirmation yet, I'm kinda assuming still that an extreme edition processor isn't any slower than a regular Core™ i7
Clock-for-Clock "Relative" Comparison only!
Simulated AMD® Phenom™ II X6 1055T 2.8GHz vs Intel® Core™ i7 920/930
As you can see, the "Average" performance advantage of the Intel® Core™ i7 works out a 4.9% . . . that little teeny blue tip represents the "Average" extra performance the large Intel® premium brings . . . . based on that alone I would have no problem scratching the Intel® system and going with the AMD® kit as based on a average set of results it seems to offer tremendous bang-for-buck ££ . . . However basing a decision on an overall average of one set of data is really not giving the Core™ i7 chance to demonstrate its worth ££ . . . . still working from the same set of data I decided to peak a bit closer to see if appraising each set of test results individually would paint a different picture . . .
Hmmm? . . . well I can see a bit more blue bar . . . Far Cry 2 looks promising for Intel® . . . Fallout 3 and Left 4 dead sees the AMD® chip matching the more costly ££ Core™ i7 for FPS . . . nice one AMD® . . . on the multimedia authoring side of things the Intel® edges out in front again? . . . at least in this set of data . . . the question is though, if given a finite amount of money does that extra performance "justify" the large price premium? . . . bang-for-buck or obvious diminishing returns?
I think I would need to spend more time pawing through performance data before I felt comfortable making a decision, as always bench results vary from website review to website review but I would need to see something special coming from the Core™ i7 system in order to spend the extra . . . If the builds were AMD® the "saving" could be put towards a really nice SSD which should impress . . . . however if I can see some solid results where the Intel® really does something special then the money is there!
Another consideration that needs to be made is on the Overclocking side of things, seems like a good idea to squeeze a reasonably good processor frequency from either system although as they will be running solidly 5 days a week I don't see the need to be pushing either systems to the brink . . . . Am I right in thinking the majority of people on these forum do not run their systems at the highest possible overclock? . . . there was a poll done at the beginning of the year which seemed to indicate most non-benchmarkers are now content to find a happy medium between speed and power-consumption so I'm fairly safe to assume these chips are whizz-bang enough with a "balanced" overclock to chomp through anything?
I've specc'ed up a half-decent cooler which can be used with either systems, I don't think either system will need a massive clock to happily make mince-meat out of the duties required . . . if the power consumption is reasonable and stability is good then perhaps there is scope to eeek a bit more out but these are offsite systems which I don't want crashing or glitching etc . . . my opinion at the moment that if push comes to shove then the Intel® system would likely overclock a bit further but as these are not benchmarking machines I don't think I will be needing 4GHz clocks just yet!
I'd be really grateful to get any help sifting through the various sets of data spread out across the interweb to help highlight the Pro's and Con's of each system . . . I'm sure there is some good "Justification" out there to help anyone in the same position reconcile the price difference but so far I haven't found anything really compelling where the Core™ i7 system just screams to be bought . . .
Please may I request that no alteration is made to the "considered" O.P System-Spec and that we try to conduct a friendly and informative on-topic discussion . . . if you feel like anyone is over-stepping the mark and breaching forum protocol please don't respond directly and instead use the RTM function
. . . Fire Wizard has expressed an interest in this topic himself so let us forum denizens work out how to co-operate better on the task in hand and hopefully no one will get toasted!
[Technical Focus Of This Thread]
- Full HD (1920x1080) FPS/RTS subsystem (will take GPU request to other subforum)
- Multi-GPU capable motherboard (using single card but option is required)
- Encoding/Re-Encoding & Rendering Duties
- DDR3-1600 Memory with upgrade potential
- SATA 6Gb/s/USB 3.0
- Additional CPU cooling for quiet operation alongside a decent day-to-day overclock
- Reasonable Power Consumption
- As much Bang-for-Buck as possible!
- Purchased *new* from OcUK
- Not waiting for Sandybridge/Bulldozer
- Does either system in this O.P have any advantages/disadvantages that are not obvious from the performance data?
- Do both systems in this O.P scale up equally in performance when overclocked
- Do both systems in this O.P scale up equally in power consumption when overclocked? (will be running approx 40 hours a week)
- Can any performance advantage of the premium system in this O.P be "Justified"? . . . if so please explain how in RealWorld terms
). But before we all jump in can i just ask why you aren't willing to change the considered system specs? doing so means cheaper (and equally well performing) components can't be used?
. . . although your suggestion would be £22.00 cheaper than the LGA1366 option but again I take a Tech-hit and lose the possible benefits from less ram, no tri-channel and downgraded PCI-E 8x/8x . . for a £22.00 "relative" saving . . . .
