Over the years I have built many systems for myself and friends, upgraded, removed viruses but through these years I have steered clear of making a water cooling rig for two main reason. Cost and Fear. From what I can see if you want to build a CPU/GPU/Chip set system you are some what forced to buy the higher tier boards otherwise you won't find chip set blocks. And unless you buy a factory GPU you may if your unlucky kill your GPU getting the HSF off and the water block on, specially if the water block doesn't quite fit those VRM's as promised in the manufactures blurb (as read on here).
So I have been reading which basically means hitting google and hoping you have put the right string in to get some good results, so I started with "Water cooling guide" and got the below
The Ultimate Water Cooling Guide
Pay dirt or so I thought
Next I thought why look outside of the hallowed pages so this time I tried "inurl:http://forums.overclockers.co.uk AND water cooling guide", but only got the sticky cooling guide which describes all the different cooling methodologies.
What I am after is basically some thing that gives you some diagrams of different ways to plumb the stuff in. Much like a house's central heating system where you might have an S plan or an equal pressure manifold system etc. Also I was looking at a Coolermaster ATCS 840 Classic Case to house my new build would running a 2x240mm rad in the roof be better that a 3x120mm one?
Also there seems to be two types of rads thin and thick (ok not the best way to describe but I was drawing a blank). In one of the manufactures sites they do both thickness but list with the same thermal stat's so is there an advantage of one over the other since they have to same amount of cores with the same core diameters.
