What about the 5850 since it's £200 now?I would defiantly take the 1GB 460 over the 5830.
The thing is i can't having a loud computer, the only way to solve this would to buy a water block + £50.The 470 is a faster card than a 5850. I would get one anyday over that and it's on £235 now.
The 470 is not that loud as people make out.
My experience was also soured by the fact that Palit sent out cards to reviewers in the UK without heat-sinks on the VRM chips, and with a much quieter default fan profile - plus of course there were no reviews for the standard version, only the Platinum version, and though the two versions may look identical in the pictures they're not - the standard version has a very basic heat-sink with no heat-pipes.
Anyone know when the platium sonic versions will be back in stock?
I've got a couple going back to OcUK headquarters. 2 will be up for grabs then so you better be quck on the mouse button!![]()
Are you taking them yourself?
I won't be happy if it has an inferior cooler and a whiny fan though!
There is a bios update by the way for your card which makes the fan profile quieter.
i dont think they will just put them back on the website.
did you open the box and that?
I saw the new bios, but on the Palit site it says it's for the the Platinum card, and I have/had the non-platinum version.
