[TW]Fox;16972043 said:I am sure it protected the pipework at the front of the engine from being nuked by an enormous sheet of perspective.
A sheet of what?![]()
[TW]Fox;16972206 said:Errr perspex actually, doh.
Don't drive over stuff then dafty
(unlucky!)
[TW]Fox;16972043 said:Well having just had more or less the entire right hand underside of my car destroyed by some crap in the outside lane of a dual carriageway I must say I'm very glad I had my (now sadly dead) undertray fitted, as I am sure it protected the pipework at the front of the engine from being nuked by an enormous sheet of perspective.
So now I only need to replace the entire undertray system and the external temp sensor and all the brackets and the wheel arch liner, not the rest of the car as well
When you find out the cost, you might just want to consider scrapping the E39.....![]()
[TW]Fox;16974842 said:Err yea good idea, lets scrap the car because it needs some money spending on new undertrays![]()
Well, the cost of the undertray on the E60 is near on £1k
Do you have a part number? Woods quoted £750 for the undertray "kit"
stormster. did you ever refit the undertray, if not, and if you dont wanna it, id happily take it off your hands![]()
