pirce estimation, watercooling
You have the best OC CPU for the ££ and you dont want to OC? You have a killer CPU in a cage let it out man :)
920s can do 4.2 standing on there head.
Anyway Water cooling is like upgrades,You need to give us a budget to work to.
Hi, just built my 1st h20 loop all told came to £300, cooling both CPU + GPU, can't see the point not cooling the CPU as well, pays dividends in this hot weather.
My i7 [email protected] living room reached 25.5'c hottest core was 67'c, but the GPU is in the same loop as well. The hotest the GPU[5870:900/1300] has ever been is 44'c.
Got to agree with Danny_75 let it out of its cage, OC too at least 4.0GHz.
Iam sorry this will upset half the Forum but £200/£300 for H20? are you insane? I spent £260 and cooled a 860/5970 to -10C. I could spend £30 and get 30C idle and 60c load. Sorry £20/£30 for Fluid?? Tap water and car antiFreeze £4.95 ( Its the same stuff just not in a £30 bottle.
As covered above, can't really do a price estimate unless you use off the shelf components, in which case 250 +/-50 is the right ball park. Second hand watercooling is pretty much the same as new, but less shiny and cheaper. Generally a good idea for a first loop.
Assuming he wants the graphics card to make less noise, and is happy with the cpu, it's a good plan. I can't think of a use for a 5870 which isn't gaming, in which case a 4.2ghz i7 chip will burn a lot of electricity for zero performance improvement. If anything the cpu should probably be undervolted.
Watercooling in an Antec 300 requires imaginative radiator placement, or willingness to have hot components under water cooling. Graphics cards don't really care about being hot, so a 120mm radiator with a slow fan will do fine. Can potentially run it fan-less. I'm currently running a 4ghz i7 chip and 8800gt with a single, cheap 120mm radiator, and as long as I don't try to run intel's burn test it's fine.
I built a GPU only loop using a Swiftech MCR220 Drive, it's got the pump built into the bottom (removable) and has a res built into the top of the rad, it's excellent if you want a compact setup as it eliminates all but two tubes between the rad and the block. You could do something similar with a single block for 220ish.
thanks guys, its a bit out my budget atm but something to think about, i will probs leave it till i can go all out on my set up and splash the cash
my i7 920 is at 3.4Ghz with a warranty from overclockers that im not keen on voiding atm espacially as i only realy use my pc for gaming.
only need the OC and watercooling because my pc is struggling with my eyefinity set up!
btw nice set ups guys!
Says the guy that sells the stuff :) Dont worry there are plenty ppl still out there that believe whats said by adims and owners.
I wouldnt use tap water any day of the week.
A final yet important consideration to make is liquid coolant type. Theoretically, you could fill your water cooling system with anything, but some fluids work much better than others. First of all, do not use tap water. Tap water has minerals, bacteria, and algae in it which will corrode and cloud your water cooling system, possibly causing a catastrophic failure.
Another alternative is de-ionized water. De-ionized or non-conductive water may seem desirable initially, because it is a poor electrical conductor, and therefore will not cause much damage if a leak occurs. However, water is an excellent solvent, and so if de-ionized water is put into a water cooling system, it will corrode the water blocks to get its ions back.
Therefore, de-ionized water is not something we recommend, either.
A good choice is distilled water, because it is relatively cheap yet pure enough to use in a water cooling system. Distilled water will not deposit harmful minerals in your system, nor will it cause algal blooms because there are no living organisms present.
It will not, however, corrode your water blocks because it is not de-ionized. There are various additives which may be added to the coolant in your system.
Ahh right. I better get in my time machine and go back 8 years and change the water before it all goes wrong and i have to spend 100s!!! lol. I had a rig running Seti 24/7/365 for 5 years, i had to clean the CPU block 4 times poss 5. O i still use the same pump and still have the pipes in the spares box! . But your right better not use it anymore I will order the £50 worth today.
Get a grip and stop believing everything what you read on the internet.
