19 Jul 2010 at 20:48 #1 Si105 Si105 Associate Joined 24 Apr 2010 Posts 915 Hello all 2 quick questions for you. Will the ATi 5850 priced at 200 on here be better than the GTX 460 sonic edition. and Whats the best mousemat on here under 20 Any help would be awesome. Thanks.
19 Jul 2010 at 20:54 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare a 1gb GTX460 for £179 is better than a £199 5850. get a bit of an overclock on it.
19 Jul 2010 at 21:05 #3 Si105 Si105 Associate OP Joined 24 Apr 2010 Posts 915 stulid said: a 1gb GTX460 for £179 is better than a £199 5850. get a bit of an overclock on it. Click to expand... :0 No offense but i'm slightly skeptical about that, do you have any figures?
19 Jul 2010 at 21:09 #4 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare http://www.anandtech.com/show/3810/nvidias-geforce-gtx-460-part-2-the-vendor-cards/7
19 Jul 2010 at 21:45 #5 Si105 Si105 Associate OP Joined 24 Apr 2010 Posts 915 Thanks. The will the overclockers UK value one be fine or will I need the sonic version if I wanted to overclock? Hang on if the 465 is the same price? Is it better being a model up?
19 Jul 2010 at 22:00 #6 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Si105 said: Thanks. The will the overclockers UK value one be fine or will I need the sonic version if I wanted to overclock? Hang on if the 465 is the same price? Is it better being a model up? Click to expand... the ocuk models are usually inno3D or sparkle models. the 465 is not worth the cash, its often slower, it may have more stream processors, but they run slower.
21 Jul 2010 at 22:44 #7 Si105 Si105 Associate OP Joined 24 Apr 2010 Posts 915 Ordered the OCuK value GTX 460. Thanks for your help.
