- 27 Mar 2004
- Between Realities
Some other aspects of going to I7-920 over 1055t are the fact you'd be going to Tri-Channel memory, Which is in itself another plus and although the differences between the 2 types at present are small the differences are there and it's another plus for Tri-Channel.
Add to that the fact you'd be gaining 2GB over the the AMD spec, which is always going to be helpful. Personally in a Windows 7\Vista environment I tend to find 1gb of your ram is pretty much your operating system's to play with. The remaining RAM therefore belongs to the other software\game you're using. Others may not agree with this. I find that 5GB of RAM would be a fantastic sweet spot for the computers these days, 1GB for the OS, and 4GB for whatever else needs it(You don't need more) But obviously 5GB is a wierd number, So 6GB is the one that makes sense, add to that the nice tri-channel advantage too.
I must say I do not believe the extra RAM would help with encoding, just the tri-channel bandwidth. But 2gb RAM extra isn't something to be ignored.
