1. Bungie mod hds- until you have done it you will never understand how well this works.
2. All fans to ultra low- good SILENT fans are noctas (good alrounders but ugly, ultra high quality though), apaches (good heatsink fans, good pressure, medium quality), silent eagles (dont know too much but prevailing opinion says these are excellent case fans) and gentle typhoons (best high pressure fans for heatsinks with close spaced fins, get the low rmp models), slipsteams get an honorable mention.
3. After market graphics cooling i.e. zalman vf3000.
4. Rubber fan mounts- careful these dont flap about though!
5. SILENT as in not the kind that has it in its sales boomf silent PSU, I hate my hx750, loudest thing in my system by a mile and it is utterly cold all the time.
6. Remove anything that does not absolutley need to be in the path of airflow i.e. cables, ssds mounted in front of intake fans ect.
7. Get the pc away from you.
8. Rubber psu mounts.
9. Acoustic foam on inside of pc case (never tried but it would reduce the rattle/ambience, probably same ish volume but less annoying noise).
10. As per CPU heatsink, wide fin spacing first, efficient design next venemous x would be my choice right now.
11. Degrill wherever practical/possible.
Once you have the above sorted, boot up, take the side panel off and start using your fingers to slow/stop fans. When you notice volume drops, you know where you have room for improvement. Trust me though, get a SILENT PSU!!!!
I dont buy into fan controllers, you are better spenidng 30 quid more and making your system run silent all the time rather than comprimising.
