windows retail re-activation
14 Sep 2003
with xp if you had a retail version after 3 months you could use the original key on a second computer/installation and it would activate fine and you could use both pc's at the same time. Is it right that with windows 7 retail no matter how long you wait you cant activate the key a second time on different hardware? if you can then using pc's witht he same key would be possible if you disable automatic updates i would think.
yes i know that. Im just trying to understand how it works because im hearing that when someone deactivates windows 7 retail on one machine to use on another (which is legal) they have to use phone activation because you activate the same key twice. What im not sure of is how they did this after original activation.
no im not. I will say it again. When you transfer FROM first pc to SECOND NEW PC, is this always via phone activation? Its quite simple mate, when you activate on your new and now only pc is it no longer possible to online activate?
I think it would be via phone activation when moving windows 7 to a new system. My brother brought a retail win 7 but uninstalled it from his pc as he wanted to put xp on and went to install the win 7 on his laptop but he had to phone microsoft as it would'nt activate.
I think that quote shows what you are trying to do and it is against the license agreement.
As in this quote i'm sure he means he wants to install win7 on a 2nd pc and take it off the 1st or am i way off.
As far as i know windows does not have the ablity to "report home" when being uninstalled like some games do.. so microsoft have no way to know that you have removed it from a machine.
So when you install on a new pc the phone activation allows them to get a new hardware snapshot and allow activation on that, thus deactivating the old install. So if you keep the old pc installed it will eventually be deactivated when you allow it to talk to microsoft via updates or whatever.
