AMD® Phenom™ II X6 and Intel® Core™ i7 Debate
tbh theres enough information/threads/sites to make the right choice.
now this thread is starting to go like other threads did about the same topic..
You didn't upset me . . . you "frustrated" me heh! :p
Do not care tbh.
You got everything right apart from flying off with your subjective opinion of what quality is? . . . . there is nothing wrong with the Gigabyte board but if you can present some "fact" demonstrating why you deem my client should spend an extra £15-£60 because you deem one product lower quality than another?
Dunno where you get this £60 from.
The "considered" AMD spec Gigabyte motherboard offers all the technology that is needed, I think there is no logical reason to pay £0.01 extra! ;)
Gigabyte it is then.
Thats great . . . the only thing is I'm building the systems . . . not you and it's not your money . . .
Do your own builds then, let me do mine. I'm not asking you to purchase whatever I suggest.
Flippen heck your persistant? . . . explain to me why? :eek:
Quote the whole sentence. Because, I would rather spend some £160 on the board now and get a cheaper Quad Core Phenom for the sake of having a future proof build. Stop raging :)
Sorry, you can hide in the realm of percentages but meanwhile none of us have percentage notes in our wallet? we have £5.00 notes and £10.00 notes . . . your giving me the fear that if I don't spend £15/£60 extra
Still £60 crossing your mind, really? It's £106.50 price difference or 13.5% if you compare my builds. I prefer to use percentages because they reflect the real cost difference at the end of the day.
now these GigaByte boards are gonna blow up or something? . . . are you scaremongering or is this there a genuine reason for your dislike of the GigaByte boards I want to use? :confused:
Nope, I have nothing against these Gigabyte boards. I made up my decision reading up the reviews of both boards.
That is a "genuine" advantage not reflected in the benchmarks although now we gone down to PCI-E 2.0 8x/8x instead of PCI-E 2.0 16x/16x
Does it matter? Same goes with AM3 anyway. PCI-E 2.0 8x/8x vs 16x/16x is a subject of no concern for current graphics cards.
If the person is not planning to overclock then they could just as easily remove the £40 heatsink from that i7 860 configuration leaving only a ~£65 difference, the stock Intel heatsinks are pretty decent unless you're overclocking heavily unlike the tiny AMD 1055/1090T ones that are extremely noisy under any kind of gaming/load.
If the person is planning to overclock to 4ghz then they should be giving an i7 920/1090T system serious thought.
BW. who's the system for u or somebody else or is this just to get everybody thinking and giving information?
has i said theres enough information/threads/sites to make the right choice. if this is real.
"Oh great Wiseman . . . why is it that my considered Intel® Core™ i7 spec is £139.78 more expensive than my AMD® Phenom™ II X6 spec??
The wise-man turns his head from the sky and looks the pilgrim in the eyes and says . . .
"it's always been done that way"
The pilgrim looks puzzled and walks away and says to himself
"I have asked a question from a great wiseman atop the hill and I am none the wiser?
If the slaves had accepted the reason they were slaves was because "it's always been done that way" they would still be slaves . . .
So now you are comparing PC hardware that will be obsolete in a few months from both intel and AMD to slavery?
I find this offensive,
Ban TBH
WTF!:mad:
"The fastest and without competition can always charge a premium however small that may be. Look at the ATI/AMD 5970 GFX card for validation of this simple concept of economics"
"I have asked a question from a great wiseman atop the hill and now I am non the wiser"
The Wise-man runs after him and says " check post 65 from Fire Wizard...Fire Wizard say evreything you need to know....Wise man Fire Wizard say " Products which don't have enough competition in terms of raw performance have always charged a premium"
pilgrim " oh right...i'll jog on then"
See ya!
You could ditch 2GB of RAM from the i7 and save yourself even more cash for next to no loss in performance
Hmmm . . . buy a triple channel system and use it with dual channel
Hey Jokester! :)
Ok it took a day to sink in but your suggestion has now peaked my interest! :D
I initially was thinking of the Intel® X58 Express carried a premium compared to the Intel® P55 Express . . . therefore offsetting some of the cash saved from only buying dual-channel DDR3 . . . however having had a butchers at the boards tech-for-tech it seems my initial concerns were unfounded!
I think I read someone say that instead of using 3+3 Tri Channel its also possible to use 2+2+2 Dual-Channel? . . . is that correct? . . . if so that could be a slight advantage for upgrading down the line?
PCI-E 2.0 16x/16 is not to be sniffed at either . . . not that's its a huge incentive right now but I think if given a choice between two boards costing the same one with PCI-E 2.0 8x/x8 and PCI-E 2.0 16x16 most would opt for the latter! . . . I'm not aware it makes much difference in 2010 but a few years down the line it may be useful . .
Anyway thanks for an interesting suggestion! :cool:
Hello Fire Wizard,
firstly forgive me if you felt my last post was admonishing you, I just felt it was ironic that while trying to demonstrate to another forum member how to make a "fair" like-for-like (or tech-for-tech) comparison through your words you illustrated the concept by making an "unfair" comparison! . . .
Firstly, I was not trying to illustrate anything. The specifications which I created in my first post was not a continuation to the first part of my post in response to Easyrider. I said to Easyrider that if you're going to downgrade a component for one system, you also need to do the same for the other, otherwise it is not a fair comparison. My response to Easyrider ended there and then.
using this comparison you "roughly" concluded that there was a £100 price difference . . £100, £100, £100, £100 . . . how many times do you need to repeat a figure based on an irrelevant comparison?
If you had added the cost of a cooler to make the machine work and specc'ed a SATA 6Gb/s/USB 3.0 enabled board (as requested in the O.P) then I question where this rough figure of £100 comes from?
I'm afraid it appears I put a lot more emphasis on something which was largely irrelevant to the point I was trying to make, which was a mistake on my behalf. The price difference between both systems was not what I was going after. What I was trying to portray was if you compare two systems (A and B) which are at different price points, if you don't think the more expensive system (A) is worth the extra over the cheaper one (B), going ahead and purchasing system B based on that alone would not be the right course of action.
Are you saying you think I've done enough research or are you telling me I have done enough research?
The truth is whatever you think the reality is I haven't done enough research yet . . . I have barely started and won't be reaching a peak for many weeks yet? . . . I have contributed one set of facts to this debate and have spent many hours presenting my findings and writing posts to share my research . . . if at least five other people put time aside, collected some data and presented it with a supporting argument then this thread would be a lot closer to its peak . . . as it stands it is just myself, wannabedamned and Mr Krugga that are working together to scrutinize "facts" and are basically on the same page . . .
If you are in anyway suggesting you want this thread to end then I put it to you that you will not be serving the best interests of the forum members and depriving myself and other interested parties from the "right" to conduct a polite and informative discussion . . . I want to be sure that I am spending my clients budget properly . . it's a big budget for a big project, four machines . . .
Please feel free to join in with the topic, please respect the O.P and the "considered" spec . . . the aim of my research is to uncover the benefits the premium brings and if its worth paying . . . there is a lot of information to sift through and I am only one person here . . . please can you help me analyse the data, can you collect some of your own data and crunch it and post up your findings . . . this will be most appreciated by not only myself but anyone who is in a similar situation . . . depending on the outcome my client may have an extra £600 cashflow . . . it's my ethical duty to examine the two systems until any doubts I have are removed . . . .
As per a lot of your other posts, particularly surrounding this topic, you're making things so much more complicated than they need to be. Researching into whether or not system A will be the better than system B for a particular users needs is not rocket science, but yet you're making out as if it is.
I would probably say myself that a Intel Core i7 920 system is probably slightly more expensive in relation to the performance difference to a AMD Phenom II X6 1055T system
Big.Wayne said:
Thats fine . . . but that's actually your opinion and your "subjective" view of what is expensive and what is not expensive . . . meanwhile I am looking at two builds, like-for-like, tech-for-tech, one costing £400.86 and another costing £540.64 . . . to me £136.78 premium on one system is not slightly more expensive is a lot more expensive based on my subjective opinion . . .
The following is the entire part of my snipped post above.
I would probably say myself that a Intel Core i7 920 system is probably slightly more expensive than it should be in relation to the performance difference to a AMD Phenom II X6 1055T system. Though, products which don't have enough competition in terms of raw performance have always charged a premium.
Let me clarify what I meant by the above. The overall cost difference between the two systems is, and lets use your figure, £136.78. The Intel system doesn't necessary represent a performance increase equal to that off £136.78, but say for example represents an increase equal to £80. The reason why the difference isn't £80 but is instead £136.78 is due to those products generally being better than the competitors products and thus, charge a premium due to that very reason.
I've got two objections this with statement . . . firstly I think both builds I am looking at have plenty of "raw performance" but I am not yet able to tell with certainty which tasks perform better on which system . . .
I don't know how you are either? . .
Well, I do have an invisibility cloak which I use to sneak into highly top secret buildings as well as my sacred futuristic laser beam to cut through the vaults where they stash the reviews and benchmarks of the systems like the ones which are being discussed in this thread, which is what it would apparently take to form a reasonable answer about this topic, along with years of research.
if it turns out that the AMD® Phenom™ II X6 has more "raw performance" in the tasks that I needed it for and you are suggesting I buy Intel® Core™ i7 this would imply that you are giving me unwise advice . . .
Yes, it would be unwise and I haven't suggested anything.
Secondly your statement is fallacious in as much as you are suggesting a policy, behaviour, or practice is right or acceptable because "it's always been done that way."
I'm not quite sure how you have come to that conclusion. I simply stated products which consistently perform better than other products on the market charge a premium not necessary in relation to the performance differences due to being the top dog. I did not share an opinion regarding whether or not I think that's right or acceptable.
For arguments sake lets say the Intel system is faster in the tasks I need it for, this assumes we have all done tons of research and reached an undeniable conclusion . . .
Yes, you need to take the time out to research things to be able to form an accurate answer. However, you certainly don't need to do the rocket science type research, which you appear to be suggesting, to form one.
this still leaves us to "question" why is it that the premium is so disproportionate?
I'm guessing what you mean by the above is a 33% increase in price doesn't represent a 33% increase in performance? Well, we don't live in our own fairy tale world where everything makes logical sense all of the time.
*Snip*
If the slaves had accepted the reason they were slaves was because "it's always been done that way" they would still be slaves . . . if woman had accepted the reason there had little rights compared to men was because ""it's always been done that way"" then they would still have no rights . . . the Argumentum ad antiquitatem is an extremely popular fallacy in debate, hopefully you won't make that mistake again . . .
Please do not pull a fallacy into a discussion, one which I have not made. You have read my post and assumed what I had written, I agreed with when I was merely highlighting the reality of things.
I agree, It would be most "unwise" of me to make any assumptions based on a single set of performance data . . .I urge you to help me achieve my goals in this thread . . . I am not yet sure which way to go because I have only "examined" one set of data . . . as basic as my findings are they represent many, many hours of my time and research . . .
Good and I will try and create some specifications soon along with some figures.
alL I want is the Truth . . .
You're making this sound like there is some kind of terrible conspiracy going on here.
[Fire Wizard]
You have a conflict of interests in this thread, on one hand you are a computer enthusiast like myself, on the other hand you are an OcUK Don, do not confuse the two roles to enforce your viewpoint, I respect you and enjoy your posts but I will not be told what I can and cannot discuss when the discussion is perfectly valid and perfectly reasonable . . .your input to this thread has been most welcome and I'm sorry again for taking you to task over your "Mismatched" hardware, hopefully you can see the funny side of it!
No, I do not have any conflicts of interests in this thread, nor any others which I participate in. I wrote my post as a member of these forums. The fact that I am part of the moderating team, I can say for absolute certain, had absolutely no influence in what I have said and I would have said the exact same thing if I wasn't part of the moderating team. That, I can assure you off.
I'm afraid it appears I put a lot more emphasis on something which was largely irrelevant, which was a bad mistake on my behalf. The price difference between both systems was not a point I was trying to highlight. What I was trying to portray was if you compare two systems (A and B) which are at different price points, if you don't think the more expensive system (A) is worth the extra over the cheaper one (B), going ahead and purchasing system B based on that alone would not be the right course of action.
Well, I do have an invisibility cloak which I use to sneak into highly top secret buildings as well as my sacred futuristic laser beam to cut through the vaults where they stash the reviews and benchmarks of the systems like the ones which are being discussed in this thread, which is what it would apparently take to form a reasonable answer about this topic.
Yes, it would be unwise. However, I haven't suggested anything.
And a invisibility cloak as well as a futuristic laser beam? Seriously though, yes, you need to take the time out to research things to be able to form an accurate answer. However, you certainly don't need to do the rocket science type research, which you appear to be suggesting, to form one.
Good and I will be creating some specifications soon.
Wise words and huge respect from me;)
Hey "flawed" is my word get your own! :p
Seriously though . . . if you can drop me a sample spreadsheet I'll be happy to give it a once over . . . this only address that one chart where it says 4.9% yes? . . . I'm not sure how I am getting lumbered with all the work hehe! ;)
wannabedamned posted the data in post 70. And yes, my nitpick was purely about that one table. I agree with the rest of your data.
It does mean that this chart you posted earlier is wrong:
The blue bar should start at roughly the 90% position and fill up to 100%.
Intel Core i7 870 is on average 0.2% faster than Intel Core i7 940, based on 31 benchmarks above
Now, I wouldn't personally conclude that clock for clock Lynnfields are faster than Bloomfields BUT it shows that the differences are negligible and for an average user who does not overclock the difference is not existent. There ARE however some tasks where Bloomfields perform significantly better. I would imagine that with a higher clock those differences would only deepen.
Nonetheless, the above comparison shows that Lynnfields are not slower than Bloomfields and should be treated equally when speaking of performance kings. There is Triple Channel and more memory that Bloomfield is benefiting from but there is also Turbo Boost on the Lynnfields side. I do not have a clue how Triple Channel helps to beat Core i7 870 in some of the tasks that were part of the benchmarks but I would have thought that the differences between Lynnfields and Bloomfields were the latter comes out a winner would disappear thus running the conclusion that they perform similarly, to say the least, when measured clock for clock.
There is a comparison of Core i7 860 and Core i7 920 I can attach here but measuring stock vs stock performances draws the Lynnfield a clear winner.
All right then, can you tell me how inaccurate these benchmarks are? I would have thought that Phenom II 1055T should have an edge being a newer CPU. Obviously I'm wrong? You know better, show us the prove.
show us the proof? go look in the i7 vs x6 media encoding thread....
the latest version of the h264 benchmark didnt include the actual h264.exe that has the x6 optimizations once someone told us to replace the exe in the benchmark with the latest one all of the x6 results gained atleast 25%
what more proof do you need most benchmarks are flawed unless they are up to date and include optimizations for both chips something which wont happen when benchmarks are performed at times often months apart
Ok then, explain this Mr I Know Better - http://www.anandtech.com/bench/Prod....48.49.50.53.54.55.56.57.58.59.60.61.62.63.64
a lot of benchmarks are biased from which ever site theyre from one will always lean towards a side who benefits them
the only way your gunna get true facts real benchmarks is if you line up similar components and bench side by side and record it or view it yopur self.
also what is true is a lot of these benchmarks are not upto date or havent had newist drivers so they are fully at there best.
the pricing structure is often the real tell tale sign off which is faster but not always.
the whole post is just amd vs intel.
get someone at ocuk to do a couple of tests or people on here with similar rigs and a selection of benchmarks that people agree on
I disagree, you don't update CPU drivers and AMD Phenom II X6 being a new processor should have an edge with theoretically improved software. Or looking at that from the other point of view, Phenom II processors are older architecture thus software is better optimized for them. I'm not bashing AMD CPUs in any way, just saying that these benchmarks DO reflect real performance differences and if you have doubts, prove me wrong. I read a lot of reviews before where there were different benchmarking techniques and overall gains of Core i7s would remain the same. In reality there's no performance improvements in new versions of software but rather bug fixes.
The benchmarks speak for themselves and no amount of PJC is going to change that.
Mr Krugga you are totally correct in your above post.
This thread is contrived nonsense and should be closed.
There is a reason AMD stuff is cheaper its basic economics.
i5 750 is faster in games and cost's less but this gets ignored for the sake of PJC
Its sad IMO.
I can quote rjkoneill (ocuk Don) who gets paid for testing all the latest Kit.
Both AMD and Intel....Impartial beyond doubt and yet he has stated that i7 is faster than Hex.
You lot are ruining these forums by posting gash.
You have all been hooked into a contrived baiting thread to massage the OP's ego.
Its that simple
