Cinebench 10 i7 V X6
Caporegime
24 Dec 2005
Autonomy
OK
so you can download it from here
Extract and run the 64 bit version
Perform the Rendering 1 cpu test
Perform the x cpu test
the second test will max out your cores 100%
Post a screen shot with your username below left results box and post your results so they look like this so I can copy and paste a table If you don't I will not iclude you in the table
1: easyrider i7 920 @ 4ghz 23208
2: setter i7 920 @ 4ghz 23104
3:ed79 i7 920 @ 4ghz 23062
3: Gareth170 x6 1090 @ 4ghz 21751
Just ran this a couple of hours ago after my first real i7 overclock on my new Megahalem cooler.
Results as above @ 4GHz - think it'll go higher but it's already too hot for my liking...
Damn, just seen I'm 3rd of 3 (aka last) :)
6.5% quicker? is that the difference between mediocre and the fastest there is?
Guess another way to test would be an i7 970 or 980 with hyper threading off. I notice the single thread scores are a lot higher on Intel then Amd. Can't argue with the Phenom for value though.
CINEBENCH R11.5 AVAILABLE HERE (Official site):
http://www.maxon.net/downloads/downloads/cinebench/cinebench-115.html
how about using the latest version instead of rusty ol R10 ;)
FULL 24/7 - 24hr Prime blend stable - non of that suicide overclock crap here ;)
ALL Fans on silent - can't do with performance if it sounds like a jet engine
Cinebench R10:
1 X 4637
x X 22881
Cinebench R11.5:
CPU: 7.12pts
Seem's like the hex don't scale too well, possible pointing to the shared cache i'd imagine. with two extra core a hex should theoretically be doing 1.25-1.5x more work than a quad but that isnt happening.
for example, 14,388 is what i just got with my 3.6ghz quad. Id expect a hex at 3.6ghz to get something in the region of 18k-21k, but it takes 4ghz to reach that with a hex.
Gareth was it definitely load all 6 cores?
pls change to latest version of cinebench - we want the latest optimisations right?
R10 - still not much in it like I said before mate, try R11.5 - I think thats where you'll see the gains people talk about
