OK
so you can download it from here
Extract and run the 64 bit version
Perform the Rendering 1 cpu test
Perform the x cpu test
the second test will max out your cores 100%
Post a screen shot with your username below left results box and post your results so they look like this so I can copy and paste a table If you don't I will not iclude you in the table
1: easyrider i7 920 @ 4ghz 23208
2: setter i7 920 @ 4ghz 23104
3:ed79 i7 920 @ 4ghz 23062
3: Gareth170 x6 1090 @ 4ghz 21751
