*Official OMG I got my 460 thread*
Ok, inno3D card installed with everything up and running. Firstly, this card is pretty much silent in my PC, much quieter than my case fans and it really makes my old single slot 8800gt seem very loud. Temps seem to be pretty good at 39C idle and no higher than 70C load, my case is a smallish HTPC case with fairly poor airflow. My old 8800gt used to idle at 60C and get up to 90C under load, but then it was on its way out. So far so good ....
But performance doesn't seem much better than my 8800gt.
I've got a 8800gt single-slot cooler (god I wished I'd waited for the dual-slot coolers), mine is so noisy in-game it's unbelievable. I won't miss the noise one bit with the GTX 460!
Cooling is good in my Antec P182, but I do have to switch the case fans up a notch or two to keep the 8800gt from hitting ear-piercing scream level.
My processor is q6600 @ stock.
Also I can't seem to activate the digital sound output, in the sound devices bit in windows it just says no audio device. My onboard sound has been broken for ages and is disabled in the BIOS. Any help?
Not sure if i was imagining things but I think I read somewhere that the Digital Audio sound only worked with the latest PowerDVD version and wasn't enabled for anything else at the moment?:confused:
ok guys, got a report for you, sorry for delay
installed win7 for first time to try the card, gainward gtx 460 1gb gs
rest of my specs in sig.
EDIT: forgot to mention, the GS comes with the same copper pipe heatsink as the GS GLH model, and I suppose the palit sonic platinum too. There is no vrm heatsink of course.
Reports suggest the palit sonic has a different heatsink though?
video bios,
the card appears to already come with the latest video bios which is available for download on the gainward product page - as when I tried to install the new bios it said no found any supported video bios. gpu-z and expertool confirmed this, along with the help of me finding out the old and new bios codes from some german site.
fan speed
sounds alright on idle, got around 35c and 40% fan speed but it is audible over my other fans, you can hear the low faint whine, and I never had that with my 8800gtx reference blower cooler -which was quiet whooshing like my arctic freezer 7 pro, have 3 x 120mm antec tri cool fans going in my p180 on low, arctic freezer 7 for cpu set to optimal speed (between performance and silent), and the hiper psu fan is extremely quiet.
when I tried the windows experience index, during the aero/3d tests, its just a progress bar as most of you probably know, I became concerned when the fan started speeding up, and it became annoying quite quickly, was worried about game performance.
temps, fan speed with game performance, 1280x1024
have tried one game so far, installed riddick escape from butcher bay (not the steam version), start level outside the prison i think it is, with everything maxed, and vsync set to on, the fan can clearly be heard revving up but still sort of acceptable i suppose, if you disable vsync to get more fps (which I usually always have done, unless it causes problems), the sound becomes quite unbearable and it made me think of a jet taking off or a washing machine drum getting faster but on a smaller scale. I havent tried it with game sound over speakers or my headphones yet of course, but it's clearly nothing like my 8800gtx blower which couldn't be heard like that at all, there is a distinct whine to the fan performance both faintly on idle at 40% and clearly more aggressive at 60%-70%. With a load temp of say 50-60c, the fan speed % always seems to be about 10 units maximum ahead of the c temp reading.
I put my audio technica ath m50 studio headphones on which have excellent isolation on them and the whine was easily heard through them, make note without sound on though, but during quiet moments if you were playing a game, you would be hearing this whine on load.
am not doubting this cards ability to perform, as it definitely has the horse power to give amazing performance for the money, but this cooling solution, the fan specifically I mean, I am not sure it is satisfactory, especially for the money - why is there such a whine when it should be a whoosh. Whoosh surely > whine ?
next steps
I am going to give unigine a go, and a couple of other games.
I am also going to limit the fan speed with expertool and see what the sound and temps are like, perhaps try no more than 55% fan speed.
If I can't become satisfied, then the card is going back, and I will look into the inno, which people have reported as whooshing because of its blower cooler (like the 8800gtx I suppose), or the msi or giga, need more reviews of the msi. card with a reference cooler might be good too.
I really love what gainward have done with the card pcb design though, made it a lot shorter, it's such a cute little thing putting it into my case compared to the 8800gtx, I would even have np in my case to go sli with 2 gainwards, as the length means a second card doesnt block my sata ports in the second slot (the whine of 2 might kill me though). Having 2 msi which are longer would be fine because it doesnt have a large enclosure.
decisions, decisions, well for me £200 is a lot of money to spend - I took some photos too which I'll try get on here soon :)
update,
before limiting fan speed, did a benchmark test of Unigine heaven.
Not sure what the min fps was about as it started off fine, could be down to this old 80gb ide hd I am testing it on and was a hiccup somewhere. Performance was impressive I suppose!
Unigine
Heaven Benchmark v2.1
FPS: 38.6
Scores: 972
Min FPS: 3.6
Max FPS: 86.1
Settings
Render: direct3d11
Mode: 1280x1024 2xAA fullscreen
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Replication: disabled
Tessellation: normal
And then, using expertool, I changed the fan speed to fixed, 55 wasnt very nice, nor 50 really, 45 was alright, so I put it to that.
Fired up riddick butcher bay for a bit, temp didnt really go over 64c with that fixed setting. It might be a different story during a hot summers day.
Downside is it has to be 45 in idle too, as the expertool fixes both 2d and 3d fan speed sliders??? can't appear to unlink them.
I don't know guys, don't think I can put up with the whine even at low pitch/volume, at fixed I might kinda forget about it, but I'd be worried what such a low speed might do to the card over time. On dynamic whenever the speed changes - any kind of change due to gpu load, you hear the change in whine pitch clearly - and that's what most annoying, the change in the sound. My case is supposed to be pretty good at masking noise because of the materials, and I have 3 x 120mm case fans going, on low speed yes but the combined low whoosh noise is dampened, but this whine can cut through really. Hearing quite a bit of low volume capacitor (remind me if I'm wrong) squeel sometimes having vsync off, during gameplay, didn't have that with my 8800gtx - although was natural to hear it heavily in a menu screen.
Yet another report.
I picked up the early 768 MSI model, its basically the reference nvidia card with the stock cooler. It seems replacing this cooler was a mistake by most manufacturers judging by the amount of complaints, this one is pretty damn good actually.
I'm running the card at 850 core, 1700 shaders, and 4200 ram, with a slight nudge on the voltage at 1.025v. I've set the fan to run at a fixed 45%, at 50% it was resonating with something I couldnt find in the case, and at 55%+ the air whoosh becomes noticable. At 45% though it's barely audible over the case fans, and the highest temp recorded by Afterburner all day has been 59°. I just played NFS Shift for an hour with all the settings cranked and the highest recorded temp was 55°. It idles at 30°.
Speaking of which, the idle/2D/3D throttle is annoying the hell out of me, my last card was a 8800GT and I gather all nVidia cards since then have had this severe speed mode switching, and I'm not sure I'm liking it. It seems fine for most games but it doesnt seem to recognise Bad Company 2 as a 3D game until I actually get into a server, and then sit there for 10 seconds at 2 fps while the drivers realise whats going on and spool up the clock speeds. I wouldn't mind so much but the power saving mode is a load of tosh anyway, since having any video clips up, browing youtube etc, puts everything into balls out 3D mode. It also does this with a standard screensaver which is a real face in hands moment.
Gripes about the crappy power saving aside I'm delighted with the card, paid £155 and couldnt have done better really, it hasnt performed miracles with badly made/ported games (BFBC2 and GTAIV in particular) but fps in many others such as AvP and Dirt2 has tripled compared to my old 8800GT. :cool:
This is the reason I returned my Palit Sonic (non platinum) card. Paradoxically the whine is more noticable when I'm wearing headphones because the whooshing of my case fans get filtered out so all you can hear is the whine. It's not a problem when there's a lot going on, but during the quiet moments the whining is really really really irritating. I also returned it because of the inferior quality heat-sink. Just waiting on a refund now. (This is from a different supplier).
I don't know why these companies have all abandoned the reportedly excellent stock nVidia designed coolers and gone for their own solutions which are much worse. Even EVGA, my preferred brand normally, have done this and their cooler is very noisy and doesn't do a good job of cooling either.
To the people limiting fanspeed, why not limit the speed to 35% or 30% and see what the GPU temp is under load, if it stays below 95C it's fine.
It'll hit way higher than that.
I was getting low 90C's with the fan limited at 50% on the Palit.
That was in Metro 2033, which really gives your GPU a good thrashing, almost as heavy on the GPU as furmark.
ahaha
the 'GS' 470 has a core of.... guess....650....up from 607...
i had my zotac gtx 470 @ 775!!!
Temps, noise, power etc?? No denying the 470 is quicker just a comparison, at them clocks you get similar performance to GTX 470 OC yet better thermals, noise and power usage plus a little cheaper.
honestly they really know how to screw up what should have been a great release, good perf/price/temp, they just had to cheap out on the coolers...ffs
The fan on the KFA is really quiet, hardly a wisper from it, I had to take the side of the case off just to see if it was actually spinning.
