could just be the actual units aren't working as they should. best bet is to try some cheaper ones. if they don't work send them back under dsr.
mine were £35 second hand and work flawlessly. i know we've different houses but i'd still assume they'd work just as well.
Hmm you think it could be crappy Belkin made plugs? I was told that brand does not make a difference.
Do you run your net connection across the plugs by any chance?
there is a box on the end of the street but u can't touch that, the cable which is phone + date cable go under ground up to your 2 boxs
Er so how do the engineers extend the cable that comes up from the ground? Is there some kind of f barrel connector that they then screw onto it or something?
Unfortunately I have home insulation so Im guessing it would be difficult to feed the wire down the sides (how easy is it to access the bit down the sides from the loft? Never thought about looking tbh!You could just lay it across the loft but it would be easy enough to tack it down with regular coax clips. Your speed won't degrade with length, cable broadband is almost like a 'it either works or it doesn't' service unlike ADSL where length is very important to your sync rate.
I'd probably try and keep all cables internal if possible, if the internal wall is hollow/plasterboard you could even try and be clever with dropping cable down the void - that way you don't have to worry about cables being on show.
Just broadband, dont have TV.ben said:As above, what boxes are you moving, both tv and broadband?
ben said:Oh, and I've just seen your other thread. I have been playing with wireless N recently and am not overly impressed with it. The laptop connects at 300mbps but the max throughput I receive sitting next to the router is 8MB/sec and this rapidly declines when I walk around the house with laptop in hand. 5GHz and N don't like distance!
Hmm sounds like a miss for me too then!
