Cinebench 10 i7 V X6
Well so far my 1055T has beaten the i7 920 in the latest benchmarks. We cannot look at individual cores, we have to look at the CPU as a whole since that is what is being used.
The conclusion ive made is this.
1055T > i7 920
1090T > 1055T
980x > 1090T
If this is was you want to believe than that's fine. But this is not the case due to many factors not just including one bench.
The problem is, How much of the software out there is optimized for hex core. if the worlds software was infact optimized for hex yes. The hex core is better. But in the grand scheme of things the remaining software will benefit from the faster(Higher IPC) I7 cores.
Cinebench 11.529:
Apparently you cannot use that benchmark because the world is still using single core processors.
Obviously you cant comprehend what's being talked about :) No one is saying that benchmark cant be counted. We are all in agreement that hex core surpasses I7 in hexcore optimized programs. Where you're failing to keep up with us, is in the department that a lot of the worlds software doesnt use it, and in those departments the I7's Higher IPC on each core comes through. In all those millions of pieces of software where hex will never be introduced, in all those programs where Quad will never be introduced. in all those games that will not use more than dual or single cores. Those programs are the ones that benefit from I7.
So we are no longer comparing the HEX against the i7s we are now comparing individual cores?
NO im not saying that,im just saying the intel chip is more up to date tech,the Amd chip is based on older tech with 2 extra cores bolted on.
From this benchmark 11.5 and the other video encoding benchmarks the 1090t is faster but you could also look up another 20+ benchmarks which show the intel being faster,because its got more grunt per core and these programs are not optimized for x6.
IF everything was optimized for x6 this wouldnt be a problem,but by the time the developers catch up,we will all have moved on to yet another faster chip.
I have no problem with accepting that, but people on here have a problem with an AMD chip beating an intel chip.
I think the only person with that problem is you :p
We concluded the findings a number of post's back.
Maybe re-read the thread and catch up with the rest of us.
We are now all hugging each other:D
Things like sli and xfire on x58 need to be taken into account.
Software usage.
i7 is faster in games too,
But its all about personal choice.
Hug?:D
Sli/xfire was my main consideration when building this rig, currently running a pair of gtx 275's, pretty cheap they were as well at £230.00 for the pair, might not be the latest DX11 cards, but they handle anything i play easily enough at 1920x1200. Gotta say though, the amd chips certainly do represent good value for money, im actually considering a new amd based rig as my second machine, an old s939 a64 4000 is on its last legs.:(
Oh and obligatory hugs all round.:D
WoW is CPU limited more than any other game if you have the settings high enough, it is a prime example of a piece of software that benefits more from an outright faster CPU rather than just having more cores thrown at it.
Say for example that X6 and i7 are exactly equal at full tilt, what happens when a piece of software is only optimised for say 2 cores? you get close to 50% theoretical performance from i7 (I say close because no HT) but only 33% from the X6, so it would be (theoretically at least) about 15% faster on the i7.
The problem with X6 is you rely on developers having updated their software to make full use of 6 cores in order to match the i7 as this thread has demonstrated perfectly, if any piece of software for whatever reason doesn't make full use of all the available cores then it's clearly going to be faster on the i7.
its not massively faster though look at most gaming benchmarks and the performance is about the same.
people used to say amd are better for gaming but intel are better at encoding/rendering....
look at all the old spec me threads where people mentioned encoding or rendering, anyone who mentioned x6 were instantly bashed because they blindly believed forum gossip that intel were better at it by a huge margin.
most things that only use 1-2 cores run almost equally well on either cpu because a program only needs so much power and most of the stuff that cant use atleast 3 cores are old programs that dont need massive processing power
hug?
We(easyrider:D) have concluded that hex cores are useless at encoding/rendering. Have you not read the thread. HAVE THY NOT BEEN SPREADING HUGS!!!
Edit**
HUGS!
Well he does have a pretty sweet home cinema setup.
Im confused as to where you've got this from.
Its not what is being said atall. What is being said is if the encoder or renderer is hex-core optimised, It will perform better than an I7. But if it's not, then it wont.
