TJ07 and PC-P80
18 Mar 2008
I've really loved both of these cases, I think that they both look awesome. Currently, I don't need to get either, as I'm on a pentium 4 and a nvidia 6800 :rolleyes:
However, I've been promised a new pc if GCSE results are good :D
Seeing as the TJ07 isn't really available anymore, I'd say I'd pretty much have to get a PC-P80. I don't like the 800D, I much prefered the TJ07 to that, as it was curvy :o
Sorry for the long winded intro. Question: can I fit a double, or triple rad inside the PC-P80, if so how would I go about it?
Danke Schön
This doesn't really answer your question but there is a new TJ** coming out soon, not sure when exactly but if you really liked the TJ07 it may be worth waiting for.
the TJ11 looks like a sack of fail
silverstone have been dropping the ball from a great height in my opinion.
their last truely excellent case was the fortress v1 [FACT]
the TJ07 is available still.
between that and the p80? then it becomes a tough decision
the p80 is an excellent case. take a look at this superb example
you can fit a quad in the front if you choose to have no optical.
have a look for 'Lian Li Radiator Brackets 5,25" for PC 343B'
you can still find them at certain places. this will allow you to mount a rad in the front of the armoursuit.
i must say you have excellent taste, they were the exact two cases i considered for my build :)
Thanks guys
I'd need to have optical drives, but if I mount a triple in the front, I imagine I'll still have space for them. But then, the problem is that I'd only be wcooling my cpu, so surely air flow would be severely restricted?
I considered the swiftech radbox and putting the rad on the back, but in the room that the pc would go in, there'd be a few clumsy kids in there quite regularly, and having a rad sticking out the back of the pc wouldn't help.
Thanks mate. Being a 16 year old, I require my cases to scream pure awesomeness. That's why I foolishly bought an XPS in 05. The p80 screams exactly that, especially the spider one. I think that having 3 led fans in the door epitomises its beauty. The TJ07 has a subtle yet enchanting look about it, and it's nice and curvy, just the way I like it. Oh man, I really want a new pc now, I'm praying results day is a good day :cool:
If your watercooling get the TJ07 (There Epic got one of sitting in front of me right now)
and if you would like to just go with air cooling the TJ11 or whatever will be better.
Im also getting some cmputer goodness if i do well in my Exams, few more weeks till the results :D
EDIT: i also bought a XPS but in 07 :P.
just had a look at that permafrost system. WOW! I don't think I have the modding expertise to be able to pull something off like that, such as cutting out holes in the bottom of the case to house the rad
If you got the tools you can just look up some guides and such on how to get a good finish but more things like that you just have to take your time. :D
IF I have the system built ;)
Ha, im kinda in the same boat as you here, going to be doing some full watercooling and i havent even bulit a full computer before altho i have took my XPS to bits, cleaned it then put it back togither but good luck to you ;)
You can add me on steam if you need any help or that :D
Steam: stivalmighty
