Just took delivery of an EVGA GTX 470 SC (high airflow) but it was fitted with the regular back plate and not the high airflow version. The additional bracket is on the PCB however. I rang OCUK and they said EVGA have fitted the wrong part at the factory and I will have to contact EVGA to replace the card.
Naturally I am more than a little annoyed at having to RMA a brand new product. So question is, if ayone has experience with this card, does the high airflow bracket actually make a significant difference to the cooling on this card? The OCUK guy I spoke to said it probably makes little difference and I am tempted to just use the card as is. I can do without the time, expense and hassle of returning what is presumably a perfectly working card.
It's my first Fermi so not sure if the heat issues are as serious as some review sites make out.
Thanks in advance for any advice.
