you don't need to do any cardio for weight loss. To be fair you don't need to do any exercise for weight loss at all. It's simply a function of calories in - calories out. Exercise will give you a boost to your calorie expenditure and a (small) metabolic raise - along with numerous other benefits but it is perfectly possible to obtain a 6 pack through diet alone. In fact I think there's quite a few bodybuilders who barely do any cardio in the run up to a contest and they can still shed fat like crazy.
I also think that the metabolic slowing or 'starvation mode' is overstated much as many people tend to worry too much about overtraining when it really isn't an issue at the volumes of work they're performing.
If, for example you were to drop your calories to 1000, pop a multi vit and omega 3 caps while ensuring that you maintained 150-160g of protein a day you'd see the weight drop off and you wouldn't be immediately entering 'starvation mode'.
More important than cardio for weight loss is resistance training as this, coupled with a high protein intake, will give your body the tendency to maintain it's lean mass (muscle). a full body resistance program 2-3x weekly while cutting is something I'd recommend.
A planned break in your diet 3-4 days is no bad thing as it can give you a boost in motivation and a little spike in your metabolic response which allows you to diet harder when you come back to it.
Good luck.
Good luck.
