Anyone remember having to set dip switches and jumpers to get the right front side bus / memory / voltage settings![]()
Yes. My very first overclock was a massive 20mhz on a P166 to get it up to a corking 187mhz!
Upgraded to a DX66 around the time that the pentium first reared its ugly head.
I'm reminded everyday by my wall
snip
My first "pc" a 486 is still in a cupboard somewhere. Slowest thing on the wall is a socket 7 mobo with old isa and edo memory slots!
. My first pc was an 8086 cannot remember what make but the first 286 i had came with a turbo button that made it go from a stonking 8mhz to storming 16mhz
. Ah those were good ol days life was so much simpler lol.My PCs
> 386 running windows 3.1
> 166 cyrix with 1.2gb drive and a cirrus logic GFX card
> 400 AMD with a Voodoo 3
> 2500m AMD OC'd to 3200 Spec
> Opteron 146
I doubt it was much an upgrade over your 386.
A Cyrix CPU!I doubt it was much an upgrade over your 386.
I went the same way with the Voodoo 3/and various AMD CPU's, finally peaking with a nifty K6-3 450. I even had a MPEG 2 decoder card in that PC too. I have fond memories of that old rig.
So although the PB had less memory than the evesham, it was both faster cpu wise and more reliable lol.Considering that the 386 was either 25, 33 or 40MHz, the Cyrix at 166MHz was quite a jump. Cyrix was like AMD then, competing to produce x86 'Intel' clones. I was building PC's for others in those days, Micro D****t was in an old post office counter in Manchester and I bought a lot of Cyrix from there as they were relatively cheap for their performance.
andy
for a reason.
