- 11 Dec 2005
- Cheshire
 OcUK Extreme H2O GeForce GTX 480 1536MB GDDR5 PCI-Express Graphics Card @ £495.99 inc VAT
The OcUK Extreme H2O GeForce GTX 480 combines the fastest single GPU card on the planet with the most effective cooling solution. No need to have your Fermi card at 90c anymore, the EK GTX 480 Full Cover block comes pre-fitted and provides superb cooling with stylish looks. The OcUK Extreme H2O GeForce GTX 480 is available with a choice of block options, either choose nickel acetal or nickel plexi to match seamlessly with your system. With the option of the ultra stylish backplate, your Fermi will be the slickest on the block. All OcUK Extreme H2O GeForce GTX 480's come standard with the EK single slot 480 bracket, so you can store extra PCI devices in the slot below your card for enhanced expansion. With features such as cinematic DirectX 11 graphics, CUDA and Nvidia PhysX technologies.You can expand your visual real estate across three HD displays in jawdropping stereoscopic 3D and experience immense framerates with blistering graphics.
- Voltage Tweak Technology
- Core Clock: 700MHz
- Memory: 1536MB GDDR5
- Memory Clock: 3696MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 480
- Shader Clock: 1401MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 1 Year
Only £495.99 inc VAT.
ORDER NOW
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 1 Year
ORDER NOW
