so would you rather have a 325i with I drive or a 330i without assuming simlar spec everything else ?
If it comes to that choice, sod the i drive its the better engine and a Tom Tom for me![]()
It would be like buying Knight Rider without KITT.![]()
I have an 09 BMW without i-drive.
I'm sure i-drive rocks but frankly I couldn't give a rat's ass.
Wasn't the pre update iDrive terrible? Or can you have it updated?
[TW]Fox;17007980 said:Why compromise if you are spending £20k? And if you are not spending £20k I suspect you'll find your budget isnt big enough for a really nice high spec 330i or 335i.
budget is actually c.15k its between a 325 and 330 the 325's are falling into my budget with all the stuff I want but the 330's seem to be just out of reach or very rare.
also a few poor spec'd 335i's are dropping into budget but I think the car could end being more hassle than its worth with such a complex engine
what do you think of this one ? is there any must haves on the SE's apart from xenons/idrive/leather ?
[TW]Fox;17012199 said:Xenons are standard across the E92 range.
That one looks pretty nice and IMHO is as good as you'll get for that sort of money. I dont think this budget buys a decent 330i at all.
It's not 'Sport spec', mind.
