+1 I loved my 5770 so muchI am now going to trying the 460 the only reason am changing is its newer
Its a hell of a lot faster too.
The GTX 460 768mb is only 30 quid more expensive too.
Who would buy a 5770 now?
30w difference between the 460 1Gb and and the 5850 1gb at stock.
Where are those figures from?
Its a no contest. The 5850 is the cards to get even with the GTX470 on special offer.
Seems like it's time for a much overdue price drop!
http://www.bit-tech.net/hardware/graphics/2010/07/12/nvidia-geforce-gtx-460-graphics-card-review/11
The only review I found where the 460 used less than the 5850 was guru which I'm told is team green biased.
Regardless it's not a huge difference but it's something that should be considered.
HTPC builders with little gaming needs?
4350 would do
Not for gaming.
You said HTPC with little gaming needs...
If there's little, there must be some![]()
Then if there is some then a 460 @ 30 quid makes sense.
it should be a little cheaper though, say £110 or so.
