If you compare voltage tweakable card vs voltage tweakable card, the price difference is not as little as £20, but £35-£40.
Any reference Radeon 5850 can be voltage tweaked and they cost £195 somewhere
You certain you are guaranteed to get a reference card new from shop after the customs one took over for so long? And doesn't the reference card require flashing bios to Asus's in order to voltage tweak...which would void warranty if I'm not mistaken...?Any reference Radeon 5850 can be voltage tweaked and they cost £195 somewhere![]()
Was hoping better brand reference would be available...And yeah, VTX and Powercolor are reference models.
VTX only offer 1 year warranty and the quality of rma service is unknown...where as Powercolor...it as questionable rma since someone send their borked 4870x2 back to them within the warranty period...instead of getting a equivalent card replacement (which should be 5870 or 5850), he got refunded just £110...so a big hmmmmm there...
yea so... have u let everyone decide for you now, or are you ready to make your own decision easy?
See his sign. i7 920 and Asus P6T SE so it's X58, so both Crossfire and SLI are possible.So what is the spec of your system? Is SLI or Xfire a possibility? Two 5770s will match and in some cases just pip a 5870 and work out cheaper even if you bought them now.
To my knowledge that asus board is Xfire not sli. Unless there is a modded bios or newer bios to support it.
I'm pretty sure I was talking about the GTX460 1GB not the 768MB version. The review I saw was with 8xAA, so I guess the 5870 is performing slightly better in 4xAA mode than the GTX460 1GB in the Heaven Bench. Also, it still doesn't change the fact that it is better than the 5850 in tessellations as a single card. So again, it's down to the preference of slighty better raw power vs slightly better tessellations plus more features, and slightly cheaper vs slightly more expensive. And as useless as Physx as the people claim it to be, it is still a nice bonus for a card that is cheaper.Better tessellation performance than 5870...http://www.techpowerup.com/reviews/MSI/GeForce_GTX_460_Cyclone_OC_768_MB/28.html
