New build £500 to £600 - gaming pc
24 Jul 2010
Hi All
Looking to build a pc for gaming but have never done it before so don't want to spend £600 and not buy the best that i can for the money.
I would like to be able to play cod mw2 at a decent standard if possible.
Don't need operating system,keyboard,mouse or monitor as i have those:D
Thanks for your help.
AMD:
Product Name Qty Price Line Total
Palit GeForce GTX 460 768MB GDDR5 PCI-Express Graphics Card £155.09
(£131.99) £155.09
(£131.99)
AMD Phenom II X4 Quad Core 955 Black Edition 3.20GHz (Socket AM3) - Retail £126.89
(£107.99) £126.89
(£107.99)
Asus M4A87TD/USB3 AMD 870 (Socket AM3) DDR3 Motherboard £86.99
(£74.03) £86.99
(£74.03)
Patriot Viper 4GB (2x2GB) PC3-10666 1333MHz Dual Channel (PVS34G1333ELK) £70.49
(£59.99) £70.49
(£59.99)
OCZ StealthXStream 2 600W Power Supply £60.99
(£51.91) £60.99
(£51.91)
Silverstone PS02B Precision Midi Case - Black £39.99
(£34.03) £39.99
(£34.03)
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £35.24
(£29.99) £35.24
(£29.99)
Sony Optiarc AD-7260S 24x DVD±RW SATA ReWriter (Black) - OEM £15.99
(£13.61) £15.99
(£13.61)
Sub Total : £503.54
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 17.50% VAT : £90.18
Total : £605.47
Intel:
(£131.99) £155.09
(£131.99)
Intel Core i5 750 2.66GHz (Lynnfield) (Socket LGA1156) - Retail £149.99
(£127.65) £149.99
(£127.65)
OCZ Reaper Low-Latency 4GB (2x2GB) DDR3 12800C6 (1600MHz) Dual-Channel (OCZ3RPR1600C6LV4GK) £82.99
(£70.63) £82.99
(£70.63)
Gigabyte GA-H55M-S2H Intel H55 (Socket 1156) DDR3 microATX Motherboard £66.99
(£57.01) £66.99
(£57.01)
(£51.91) £60.99
(£51.91)
(£34.03) £39.99
(£34.03)
(£29.99) £35.24
(£29.99)
(£13.61) £15.99
(£13.61)
Sub Total : £516.82
DPD Next Day Parcel
VAT is being charged at 17.50% VAT : £92.50
Total : £621.07
Thankyou for the reply.
My last system was intel, what would you go for if it was you the amd or intel.
thankyou
I am going to say the Intel, I run the i7 which so far I am pleased with and fairly easy to overclock.
Hopefully you can get a good overclock with that board and after market cooler.
I'd go with RJCs amd option. However most games will not fully utilise X4 cpus (at the mo anyway) so money saved there would be better put towards a higher spec graphics card.
So you could opt for a X2 phenom II. The 555BE (around £80) would be good but buy an aftermarket cooler with it that would cool a X4. Here's why.....
That mobo supports ACC which can unlock hidden cores. Basically some X2 and X3 cpus are rebadged X4s. Do a lil googling on unlocking phenom cores there is plenty of info available.
If you can't unlock the cores the CPU is more than man enough for gaming. The improved heatsink will cool the CPU if it is an X4 or at the very least help overclocking it as an X2.
Hope this helps, good luck with the build
