- 27 Jul 2010
Hi all.
I've recently built a htpc using the above. One thing that's quite annoying is you have no control over the system fans. There is 3 of them in total and all are plugged direct into the Psu.
On my motherboard there is a sys fan port but only one. Is there a way I can change the fans to use this so the BIOS controls the speed of the sys fans as well like it already does with the CPU fan?
Also has anyone replaced the fans in this case with anything quieter?
Many thanks all,
Gav
Many thanks all,
Gav
