[TW]Fox;17038762 said:Check your coolant level.
I thought that straight away and it's fine - also gets up to correct temperature quickly and sits stable so I think it's an electrical/control issue.
Depends, if I can locate the problem I can make a decision. £80 for the condensor is fine, but I want to be a bit more convinced that's the issue. At £30 a time, every other week, it could get tedious just topping it up! This guy wont top it up now anyway because its illegal to refill a known leaking system.
I may still end up keeping it for the forseeable anyway and the AC is usefull all year round IMO
You were looking for something to replace your 407 with werent you?![]()
Yep I was just looking at that. It might be that one that's rubbing against the bracket, but I just dont understand why there wouldnt be any dye on it
Unlikely to have happened twice though, surely?
