Well, the markup?
As long as they work, they're all the same tbh. The only difference you may find is the build quality of the cable, though even at £4.99 and £14.99 there's probably not a lot of difference.
sorry lol this is what the uaction site says 5 metre (16 feet) High Quality HDMI Cable with Gold Connectors
PERFECT FOR ALL HD APPLICATIONS INCLUDING SKY HD AND PS3
• Connections: 19pins - 19pins Gold plated
• Length: 5m
• Color cable: Black
• Color plugs: Black
High-Definition Multimedia Interface (HDMI) is rapidly emerging as the connection standard for HDTV.HDMI combines high-definition video and multi-channel audio in a single digital interface to provide crystal-clear digital quality over a single cable.
HDMI offers significant advantages over analog A/V connections, including the ability to transmit uncompressed digital video and audio content.
Connect your HD equipment together and see the difference! Manufacturers HD equipment comes with basic, inferior HD leads. Why compromise on quality when you have invested so much in your new LCD, Plasma, HD DVD or Sky HD Box? These superb leads have been manufactured under exacting standards to provide outstanding quality at a superb price.
or
Features & Specifications:
High performance quality HDMI-HDMI cable suitable for use in HDTV, Home Theater, PlayStation 3, and business class projector based applications
Latest Version 1.4
Fully compatible with HDMI 1.3b specification and Full HD Bandwidth: 10.2Gbps/340MHz
Version 1.4 For higher speeds, Deeper Color & Additional Color spaces (for supported devices
Ethernet Capabilities (for supported devices)
3D over HDMI (for supported devices)
Audio Return (for supported devices)
Supports Resolution up to 4k x 2k which is up to 4 times that of 1080P (for supported devices)
24K Gold Plated connectors to ensure superior signal transfer and maximum performance
Transfer Digital Audio and Video signals at warp speed of 10.2 Gigabits per second!
Digital video doesn't get any better than this
Maximum reliability by tripe shielding (2*foil and 1*metal-braid screen) and gold plated pins(10mu)
Large gauge PVC jacket provides maximum shielding against wear and tear and extreme
temperatures
Designed to meet all HDMI standards
Treble screened to provide complete immunity to environmental EMI and RFI
Oxygen Free Copper conductor
Tinned Copper Braid Shielding
Interface: 1 HDMI Type A 19Pin Male Connector, 1 HDMI Type A 19Pin Male Connector
Color: Black
Cable Length: 5 Meter
Package Contents:
5 Meter HDMI Male to HDMI Male 19 Pin Gold Plated Ver1.4 Cable
Also see the above image showing the Package contents.
