- 18 May 2010
If you have fitted an air filter to your car either your current car or a previous one what did you fit and why?
This is just air filters please dont list any other modifications
I've only ever used replacement panel filters and an open cone filter which was promptly removed due to the fact that it actually made the car it was fitted to drive worse
These days I stick to the standard air box with standard paper filter basically because its the best compromise between filtration and flow when changing the filter regulary but the temptation to go after market is always there because of the noise and the increased power on some engines but most of the time cost per gain is rarely worth it, some companies like GruppeM for example make intake kits that increase power with no loss in throttle response due to the design but they cost a fortune
Here are some links for your reading enjoyment, I didnt write them so if you have a problem with them thats your problem, i'm just linking them for anyone thats interested in reading them, what put me off is washable filters such as the K&N's is mentioned in the Bob Is The Oil Guy link which makes for great reading if this type of thing interests you
Filtration
http://www.mkiv.com/techarticles/filters_test/2/
Cold air intakes
http://www.strikeengine.com/technical_information/cold-air-intake-cai-information.html
Filtration and flow in depth tests
http://www.bobistheoilguy.com/airfilter/airtest1.htm
Filtration
Cold air intakes
