Did you click to find optimum ratio in your simulation software, WinISD? It usually gives a shape a bit like that. Looks like Monacor drivers? What did you sim the crossover in or is it a ready made one with generic slopes? You appear to have flush mounted the tweeter, why not the woofer? With full range going to the tweeter (why is this happening!?) it'll overload VERY easily!
I can assure you designing and building really good speakers is very in-depth and complex, involving measuring, computer simulations of every aspect (driver responses, baffle step, enclosures, crossovers etc) and trials. You may get a decent result with less effort, but never anything exceptional. These are fairly budget orientated drivers, quite easy to work with too, but you could probably get more out of them.
You can get a whole range of vinyl,wood effect, stone, colours, high gloss etc. Seal the MDF (3-4 coats of Rustins) first and sand it with high grit paper, you'll need an extremely flat and smooth surface to get decent results with a gloss vinyl, less important with wood effect/matt colours
