Is this ok? Temps and voltages
list the rest of ur spec and the cooling you're using ... have nothing to compare against here
Antec 900 Nine Hundred Ultimate Gaming Case - Black
OCZ GameXStream 600w Silent SLI Ready ATX2 PSU
Gigabyte GA-MA770-UD3 AMD 770 (Socket AM3/AM2+) PCI-Express DDR2 Motherboard
AMD Athlon 64 X2 Dual Core 6400+ 3.20GHz
OCZ 8GB (4x2GB) PC2-6400C5 Dual Channel Vista Gold Series
VTX ATI Radeon HD 5770 1024MB GDDR5
DGM L2231WD 22" Widescreen LCD Monitor - Glossy Black
Microsoft Windows Vista Home Premium SP1 64-Bit
Im using the Stock fan for the CPU , the case has the following :
- 1 top 200mm TriCool fan with 3-speed switch control
- 1 rear 120mm TriCool fan with 3-speed switch control
- 2 front 120mm special black TriCool blue LED fans with 3-speed switch control to cool HDDs
- 1 side 120mm fan to cool graphic cards
- 1 middle 120mm fan to cool CPU or graphic cardsl
Sorry for the late reply.
Regards
Tab.
Idle temps don't really matter too much. Post a screenshot of your load temps and it will give us a better picture. :)
The air flow in your case seems good. How loud is your heatsink fan? That's the only thing I would change.
Hi there Tikkabhuna thanks for your reply , heres another pic under load :
I cant really tell how loud the CPU fan is , there a lot of fans going off so.. but was thinking of maybe getting this cooler what do u think.
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1156 / 1366)
Cooler LINK
Regards
Tab.
Cooler LINK
Regards
Tab.
Where is TMPIN2 80C ??
Also -12V and -5V look a bit screwy,
andy.
