Natwest Online Banking - now a pain to log in
Permabanned
14 Sep 2005
Burnham, Bucks
I would give them a call, there is no need for them to know the full card number in order (and especially CCV) to enter your online banking. It definitely sounds dodgy.
Sorry for loling earlier as well. ;)
Man of Honour
26 Dec 2003
Shropshire
That definately looks very very dodgy, they say they will never ask for your full password and/or pin and the way they want it entered makes it look like itl be read by a human
11 Jan 2008
Nowhere
Just checked mine, no change, just the usual 3 sets of info.
Edit; Looks like a scam from your image. Esp. that "Password - PIN" part
Aod
Aod
7 Oct 2004
London
Call them asap.
steps to check:
install and use a new browser, preferably Chrome.
go to http://www.natwest.com in chrome
go to the online banking login page (like you posted in the screenshot) and click the lock-logo in the address bar, which will allow you to see the security certificate details, and compare them to this:
specifically the Serial number :)
OP
30 Jun 2010
UK
Online Banking details changed, card cancelled, hopefully I've escaped any actual damage this time.
I feel like such a fool, it's obvious now that the details they were asking for were wholly inappropriate, but I'm still at such a loss as to how the URL appears legitimate when clearly I'm being directed to somewhere else? In fact I'm incredibly annoyed that the software apps I have installed haven't detected anything dodgy.
What do you guys think?
7 Apr 2004
How did it happen? If you clicked on a link to get to the Natwest login page then that's fair play and your fault. If however you manually navigated to the site and it still happened then it could be one of hundreds of possible attacks and basically as it's financial related don't take any chances and reinstall your OS from a trusted CD/DVD. No point in messing around.
OP
30 Jun 2010
UK
No, I went through Natwest.com as usual. This is what's so confusing, check the image I posted earlier, the URL looks entirely legitimate.
Aod
Aod
7 Oct 2004
London
Then your OS, browser or LAN is compromised. That image definitely doesn't look legit to me.
Agreed, benftl, do you have WiFi or ethernet only? if it's WiFi, are you using WEP or WPA?
either way, it'd be a good idea to change your WiFi password too :)
OP
30 Jun 2010
UK
Indeed, we've established it's illegitimate. What worries me is that should the questions have been phrased in a proper manner, I wouldn't have been concerned one bit as there was no other indication that the site was compromised in any way.
I'll get the cert details posted up shortly for the member who wanted them!
[edit]WiFi and Ethernet, however I'm assured my LAN isn't compromised as I use WPA2 encryption and a stupidly long password on both laptops. I can only assume both computers have become infected somehow.
7 Apr 2004
Yer the cert is fine.
It's most likely a browser or possibly OS rootkit modifying what you see, or some other clever piece of Malware.
Format -> Reinstall :)
OP
30 Jun 2010
UK
I know what you're saying, the problem is not only would a format and reinstall be a HUGE pain in the arse but also if I don't know what has caused this infection then what's to stop it happening again?
I'd rather know what the problem is than start from scratch and hope for the best. Clearly Spyware Doctor isn't worth the subscription fee, the scan is almost complete and nothing has been found.
