Hmm, that Noctua NH-D14 does look a beast...
I am looking to overclock a i7 930 to as close to 4Ghz as I can (on air) so this would be as good a choice as any..
Will it fit ok into an Antec 1200 case?
and i'm looking at the ASUS P6X58D-E board, and initially with OCZ Reaper ram, which has the heatsink fins on them, will this get in the way do you think? If so I guess I could get the lower profile corsair ram
Spire Thermax Eclipse II with 2 fans is ment to be really good (better than Noctua NH-D14 according to frostytech) or the Tuniq Tower 120 Extreme
Do you really need to do all that tweaking? Have you tried everything near as stock?
I run 1.1v IOH, 1.1v QPI, 1.8v CPU PLL, only things i have tweaked for 4.2 is vcore and vtt
Sure, here you go:
Hi Vect0r could you please give a link to the memory you used in your i7 setup.
Thanks
these cpu cooler is a bad choice (not an idea for overclocking) due to poor temperature review.Ordered a Thermaltake Frio.
that's even much better choice mate, Noctua NH14 is a king cpu cooler but it so huge, make sure your memory rams is low height (not any reaper size)Changed to the Noctou 14 now!
Yes but it not available in united kingdom nor no review on the 1366 socket as it only show result on 775 socket!
