its a metro in disguise.
Yes, in the same way an MR2 is a Corolla in disguise
[TW]Fox;17074579 said:Doesn't it also have questionable handling - so much so there is an MG issued Technical Service Bulletien to the effect it should only ever run the OEM fit Eagle F1 GS-D2 tyres, as anything else causes serious handling issues? Goodyear even had to keep making the damn things years after binning them just for the MGTF's..
I mean FFS, £1500 for an 03/04 car? This money won't even buy you a MK2 MX5, which is fine,
After reading this thread, its changed my mind about getting an MG TF![]()
Ive test drove one a few days ago and thought they were nice, interior wasnt shabby at all, good mileage and very good body work.
IT was a 53 plate with 55k on the clock and in black and he wanted £1550 for it.
I mean FFS, £1500 for an 03/04 car? This money won't even buy you a MK2 MX5, which is fine, I personally prefer the MK1, but if you're not looking for the particular driver experience offered by the MK1 MX5 then the MG TF is better in every possible way.
lol wut? Source for this please
MGR Tyre Advisory
TB0129, issue 2.
Reissue information:
- Correction to MG TF front tyre load index and speed rating.
- Addition to caution notes.
16” Tyre specification:
MG TF
Front 195/45 R16 80W – Goodyear Eagle F1 GSD2 – Part number RTE000460.
Rear 215/40 R16 82W – Goodyear Eagle F1 GSD2 – Part number RTB103120.
MGF
Front & Rear 215/40 R16 82W – Goodyear Eagle F1 GSD2 – Part number RTB103120.
Important notes:
Not all Goodyear Eagle F1 tyres are of the same construction. Only the GSD2 tyre has been developed to match the MG TF & MGF handling characteristics. Use of other tyre sizes, brands and inflation pressures may adversely affect the vehicle performance. If in doubt always contact the tyre manufacturer for advise.
Do not fit Goodyear Eagle F1 GSD3 16” specification or any other make of tyre that is not approved by MG Rover for the MGF and MG TF.
I thought mg tfs were praised for ther handling
[TW]Fox;17074696 said:Compared to the MX5, the MG TF is simply not GENUINELLY SPORTY.
[TW]Fox;17074673 said:Is the closest I can find. Much less info about these days. But they specifically caution against even other types of Goodyear tyre!
As I recall, anything with a particularly stiff sidewall is going to be okay.
Why is that? What is the problem?
When I'm driving my dad's, I never think "this is rubbish, I could have hit the apex of that corner much better if I was in an MX5", I just drive it with a smile on my face. Granted, living with one on a daily basis is a different matter, but I expect the shortcomings of such a car as a daily would apply to all of them.
Right, but you would have more fun in the MX5, and it would be more reliable, and you would have a decent driving position instead of a really bad one, so why would anyone get an MGTF?
(the answer is because of the old adage "People are dumb")
