E39 with a Corvette motor.
I have no idea what it's going to do, it's still running a little rough and still rattling when warm. I just don't trust it basically, if I did ...I wouldn't be even thinking of getting rid now, I probably wouldn't anyway as I like it otherwise.
[TW]Fox;17074693 said:Will you be able to trust any of these potential replacements? The difference between this car and your previous cars are that this car is 10 years old. Your 330Ci was 2 years old, for example.
Your issue is old cars and, perhaps, your inability to look after them (I dont have this ability either, its no criticism).
Maybe until you have significantly more money you should avoid this type of car if you cannot deal with the issues you get buying them in your budget.
There is an element of truth to that no doubt, but it was more of a case of me getting it wrong with the 540i, 540i's are fabulous cars ...it's just mine is not. If I am much more careful when I buy my next car, well I will be, that goes without saying then I think I can put myself in a better position with reliability. I can basically change cars without spending any money, maybe £1k though say, get something with lower predictable running costs, i.e. insurance, fuel, servicing etc ...and by buying one that has no apparent faults and some warranty (whatever that's worth) stack the deck more in my favour.
I could spend the money if it goes wrong tomorrow, I'd just rather not, there is a difference, and now it's at the point where I don't want to with the 540 anyway as I'm somewhat sick of throwing money at it and it still not being quite right.
I think a a really good X308 is still a good option, I can get one without really spending much ...if anything and gain some short term warranty and make damn sure it's all 100% before I buy.
I hope to get £4k for it.
...which I don't really.You're probably right.
Buying older used Jags is easier and less annoying than buying older used BMW's ...there are far more well cared for examples around. No doubt it's the ownership demographic that is the reason for this. 1-2 owner 10 year old cars with FSH seem fairly common in the XJ market ...especially if you like gold...which I don't really.
Sure I'd rather have a 4.0 litre but a 3.2 is fine really.
