2 Aug 2010 at 19:46 #1 DJMK4 DJMK4 Soldato Joined 1 Dec 2004 Posts 23,191 Location S.Wales Hi there, Which version of vagcom is currently best to use? also, does it it run ok on Vista/Windows 7 laptops or is it XP? Ta
2 Aug 2010 at 20:52 #2 Dandle Dandle Soldato Joined 4 Nov 2003 Posts 4,555 Location Ashford 10.6 is tha latest version and works fine on Vista and windows 7.
2 Aug 2010 at 21:08 #3 DJMK4 DJMK4 Soldato OP Joined 1 Dec 2004 Posts 23,191 Location S.Wales Cool beans Thanks
2 Aug 2010 at 21:11 #4 233 233 Soldato Joined 21 Nov 2004 Posts 13,558 Location Wishaw as above mine works fine on all versions of windows i've tried it on even under bootcamp
2 Aug 2010 at 21:26 #5 paradigm paradigm Caporegime Joined 26 Aug 2003 Posts 37,508 Location Leafy Cheshire Foxtrot26 said: even under bootcamp Click to expand... Which is just windows running natively on the hardware, nothing special. That's the same as saying it ran fine on an Acer Aspire One!!!!
3 Aug 2010 at 08:02 #6 233 233 Soldato Joined 21 Nov 2004 Posts 13,558 Location Wishaw paradigm said: Which is just windows running natively on the hardware, nothing special. That's the same as saying it ran fine on an Acer Aspire One!!!! Click to expand... there were some issues with previous versions running under vista/bootcamp for some reason but works fine under my win7
3 Aug 2010 at 08:05 #7 Matt82 Matt82 Soldato Joined 13 Mar 2004 Posts 16,649 vcds works on vista for me.
