E46 330 Facelift headlights
Damn, don't really like the idea of heating up a lump of plastic, the insides of the glass are filthy though and think its because of that my dip beam seems pretty weak.
are you sure the dirt is on the inside ??
They are sealed units, they're airtight. Dirt cant get inside them !!
Are you sure the plastic hasnt just been scratched ? If so polish them up with meguiars plast-x
