- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
For a limited time, we have the Corsair TX 650W Power Supply for only £59.98 inc VAT.
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) @ £59.98 inc VAT
Enthusiasts looking for the optimal in price performance PSU technology will find the Corsair TX650W/TX750W series of PSUs will meet even the most demanding of required specifications. The Corsair TX650W/TX750W power supplies are engineered using advanced technology and components typically found with high performance power supplies. With design features such as a dedicated, single +12V rail offer the maximum compatibility with the latest system components. Energy efficient circuitry capable of delivering greater than 80% efficiency ratings across 20%, 50%, and 100% load conditions make the TX family of PSUs ideal for the value/quality conscious enthusiast. With a large 120mm diameter temperature-controlled fan that is ultra quiet, yet still more than sufficient to cool the internals of the system, reliability and stability are no longer worries for the gamer, overclocker or enthusiast and high-end system builder.
- Supports ATX12V v2.2 standard and older ATX12V 2.01 spec
- Ultra-quiet 120mm double ball-bearing fan delivers excellent airflow
- 80%+ energy efficiency at 20%, 50% and 100% load condition for less heat generation and lower energy bill
- 99% Active Power Factor Correction provides clean and reliable power to your system
- Universal AC input 90~264V automatically scans and detects the correct voltage
- Dedicated single +12V rail offers maximum compatibility with latest components
- Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit - Protection provide maximum safety to your critical system components.
- High quality Japanese capacitors provide uncompromised performance and reliability.
- Extra long cables support full tower size chassis.
- TX650W Dimension: 5.9"(W) x 3.4"(H) X 5.5"(L);
- MTBF: 100,000 Hours
Was £74.99 Inc. VAT
Only £59.98 inc VAT.
ORDER NOW
Was £74.99 Inc. VAT
ORDER NOW
