I want play Farmville, no lies
19 Jan 2010
Merseyside
Looking to build a supercomputer that can max out farmville and play sims 2 for my fiances little sister. would this do the job.
(i know it wont need the dedicated 210 but it would be nice for sims 2?)
Do you already have an OS or do you need that included?
Either way, which OS will it be running?
Do you already have a monitor?
i would prolly pick up a cheap tft or crt off local forums for her, along with peripherals, i also have windows xp 32, and windows 7 32 and 64 bit.
cheers for the rename, i was a bit in the closet about playing fm. tbh im going to give her my old laptop, just gonna get 1gb more ram for it and prob buy a new battery because it doesnt hold its charge.
