Ah, OK, I have been getting confused with the actual method. My thoughts were that the LAN connection was to send the instructions re programming and that the Freesat streamed the pictures. However it is the reverse of this. Thx for pointing this out.
It is still theoretical for me at the moment as I do not think Panasonic have updated the Freesat integrated tuner in the TV with the ability to use the technology. The proposed deadline for 2009 TV's was the end of July, perhaps this evening....................
Rgds
Binty
You need to check if the TV Lan output really will repeat the iplayer image. If it is that easy then great but its such an easy way to copy HD content that it seems likely to have been shut off.
HD iplayer output is good but not as good as freesat broadcast quality
