- 25 Sep 2009
- Billericay, UK
I wonder how the new H70 compares the CoolerMaster V10 TEC (Peltier) since they are both at the same price point?
Yellowbeard,
If i upgrade from an H-50, can I keep the same backplate so that I dont have to take my motherboard out?
Thanks
Yellowbeard - why are corsair keeping it quiet and no metion on corsair forum or any test on the corsair home website ?
I like the sound of thatImagine corsairs brand combined with Microsoft syle advertising - world domination.
The H70 has the same backplate as the H50-1.
You do all know that this product is live to order.
Corsair Hydro H70 High Performance CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM3) @ £84.99 inc VAT
The Corsair Hydro Series H70 is the best choice for high performance CPU cooling. A worthy big brother to the already excellent Hydro Series H50, the H70 improves upon the design in every way.
A low profile pump and improved cold plate allow for even easier mounting to your CPU. Compatibility with all modern AMD and Intel desktop CPU sockets is included in the box. A higher-performance radiator with nearly twice the surface provides even more room for liquid to get cool before it returns to the cold plate.
And as if that weren’t enough, the Hydro Series H70 comes with twin high-performance 120mm fans, optimized for a push-pull configuration, to allow maximum airflow through the radiator. The Corsair Hydro Series H70 is the best choice for a high performance CPU cooler on the market, bar none.
- A new improved cold-plate design more efficiently transfers heat.
- A thicker radiator increases the cooling surface area for even better cooling potential.
- Dual 120mm fans with multiple speed options that let you optimize the maximum cooling and minimum noise.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiator Dimensions: 120mm x 50mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Selectable 1600 or 2000 RPM
- Air Flow: 50.35 – 61.2 CFM (per fan)
- Static Pressure: 1.8 – 2.3mm H20 (per fan)
- Noise Level: 26 – 31.5 dBA (per fan)
Only £84.99 inc VAT.
ORDER NOW
