TODAY ONLY DEALS - 06/08/2010 - G.Skill & NVIDIA!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right two cracking deals today guys, and even more so you can use your FREE Shipping with these. :)
OcUK Value GeForce GTX 260 "Core 216 55nm" 896MB GDDR3 Dual DVI (PCI-Express) - (Grade A OEM - 3 Months Warranty) @ £99.99 inc VAT
The OcUK 55nm GTX 260 Graphics Card rips through DirectX 10 games at blazing fast frame rates and enables realistic physical motion and massively destructible environments with Nvidias new PhysX technology. And that's not all, the OcUK GeForce GTX 260 Graphics Card also supports extreme HD (2560x1600) resolutions, and gives your system the power of up to 216 multi-threaded processor cores, offloading the most intensive processing tasks from your CPU to your Graphics Processing Unit (GPU).
- Core Clock: 576MHz
- Memory: 896MB GDDR3
- Memory Clock: 1998MHz (Effective)
- Memory Interface: 448-Bit
- Memory Bandwidth: 111.09GB/s
- Processing Cores: 216
- Shader Clock: 1242MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2 Dual-Link DVI-I
- SLI Ready
- HDCP Capable
- DirectX 10 Support
- OpenGL 2.1 Support
- PhysX Enabled
- CUDA Enabled
- Card Dimensions: 266.7mm x 111.15mm
- Warranty: 3 Months (Grade A Refurb)
Was [£109.99 inc VAT] Inc. VAT
Only £99.99 inc VAT.
ORDER NOW
G.Skill RipJaw 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit @ £84.59 inc VAT
G.Skill Ripjaw Gaming Series Memory is designed to optimized the high performance DIMMs for reliability in order to get gamers consistently fantastic FPS, while maintaining a solid overclock to prevent a mid-game PC failure from memory errors.
G.Skill Ripjaws Gaming Series Memory features the heat spreader design for the ultimate in extreme aesthetics and sleek aluminum cooling.
- Cas latency: 7-8-7-24-2N
- Capacity: 4GB (2GBx2)
- Speed: DDR3-1600 (PC3 12800)
- Test voltage: 1.65 Volts
- Type: 240-pin DIMM
- Warranty: Lifetime
Was [£96.34] Inc. VAT
Only £84.59 inc VAT.
ORDER NOW
Only 10 items of each one at these prices so do be quick. :)
Hmmm this ram or the Corsair XMS3 1600mhz c9?
Going in with i5 760 and the P55M UD2 board.
The G.Skill is a much higher performance part.
Its timings are 7-8-7-24 compared to Corsair's 9-9-9-24.
The G.Skill can also achieve much higher clock speeds if you're overclocking too.
Yeah, i just read up that it's a better clocker. Hmmm.. i just like the blue lol.
Ah well.. i think i'm gonna get it.. I just spent £400 on you guys an hour ago! :D
Edit: If i choose the same delivery day, will it come together even though it's two orders? I just don't want a billion different boxes.
Hi there
Nope will be in a seperate box but in theory should be delivered at the same time. :)
