- 11 Jul 2010
- ENgland, Oxford
does the coolmaster HAF x need the optional 200mm fan installed or is it fine without it ?
			It depends on what you have installed behind it, say two powerful GPU's may require it, but as its 'Optional', its up to you
 soz for the long reply forgot i posted this up
OcUK do not stocky any 200mm fans will a 220mm fan fit instead?
